FTTC - Latency decreased but speeds unstable
Craigy
Hey,
Over the last few weeks some weird things have been happening with my FTTC connection - I have a static IP on an 80/20 FTTC connection.
Up to the 5th of Feb when I ran speedtest.net tests I was getting 65mbps+ which was great - however, on the 5th Feb (or there abouts) according to samknows my latency decreased from around 47ms to less than 15ms by my speedtests became really inconsistent, wildly varying and almost never reaching the old speeds.
As far as I am aware, nothing has changed in terms of DLM intervention during these times, and was wondering if anyone could shed any light on what might have happened?
Output from my Billion 8900AX-2400
adsl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason:	0
Last initialization procedure status:	0
Max:	Upstream rate = 25279 Kbps, Downstream rate = 79982 Kbps
Bearer:	0, Upstream rate = 20000 Kbps, Downstream rate = 79987 Kbps
Link Power State:	L0
Mode:			VDSL2 Annex B
VDSL2 Profile:		Profile 17a
TPS-TC:			PTM Mode(0x0)
Trellis:		U:ON /D:ON
Line Status:		No Defect
Training Status:	Showtime
		Down		Up
SNR (dB):	 5.9		 9.2
Attn(dB):	 11.5		 0.0
Pwr(dBm):	-2.1		-2.1
			VDSL2 framing
			Bearer 0
MSGc:		18		150
B:		239		236
M:		1		1
T:		23		5
R:		0		16
S:		0.0955		0.3771
L:		20104		5410
D:		1		1
I:		240		255
N:		240		255
			Counters
			Bearer 0
OHF:		34108512		9211357
OHFErr:		85		10
RS:		0		598442325
RSCorr:		0		604
RSUnCorr:	0		0
			Bearer 0
HEC:		222		0
OCD:		1		0
LCD:		1		0
Total Cells:	87262979		0
Data Cells:	100020297		0
Drop Cells:	0
Bit Errors:	0		0
ES:		39		2
SES:		0		0
UAS:		28		28
AS:		56420
			Bearer 0
INP:		0.00		0.00
INPRein:	0.00		0.00
delay:		0		0
PER:		1.65		6.15
OR:		116.09		202.87
AgR:		80103.09	20203.27
Bitswap:	389/389		2/2
Moderator's note by Mike (Mav): Post released from Spam Filter.
1 REPLY 1
Fixes: 263
Re: FTTC - Latency decreased but speeds unstable
From what I can see interleaving has been removed from your line as your profile is now "0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off"
Can you confirm if you're testing the speeds over a wired or wireless connection?
 Matthew Wheeler
