FTTC Issues
- Re: FTTC Issues
FTTC Issues
29-06-2015 11:06 PM
Re: FTTC Issues
30-06-2015 10:23 AM
If it persists it may be worth raising a fault.
https://faults.plus.net
Re: FTTC Issues
30-06-2015 5:55 PM
Re: FTTC Issues
30-06-2015 9:33 PM
My connection re-synced maybe 10-15 times today, it would sync, then re-sync with-in the next 5-10 seconds. At one stage my circa 51MBit connection was down to circa 15Mbit.
Everything is back to normal now, but I was watching all this on the Draytek modem. I was just about to phone Plusnet then it stopped and returned to normal.
Re: FTTC Issues
01-07-2015 10:48 AM
Connection graph included below.
@JasonMassey
It seems to have happened this morning too.
Our tests have found a external fault in the network. I've raised this on Question 106651816
Re: FTTC Issues
01-07-2015 3:27 PM
Thanks for looking into this, and pleased you have found something.
You don't think it's anything to do with G.INP as around 4am this morning (I'm a software developer I work late!) G.INP on my upload was removed.
Many thanks
Jason
Re: FTTC Issues
01-07-2015 4:08 PM
Re: FTTC Issues
01-07-2015 4:55 PM
Re: FTTC Issues
01-07-2015 6:18 PM
Quote from: Matthew I don't think so as our testing is detecting a copper fault and your sync speed has dropped a bit.
Your profile is still showing as having G.INP on the upstream though.
Hi Matthew,
My Draytek Vigor stats are showing G.INP on upstream disabled. I logged into telnet and this is the line.
ReTxEnable: NearEnd 0 FarEnd 1
It use to show both NearEnd & FarEnd at 1 when G.INP was enabled both ways.
Re the copper problem is this something you need to look into, or should we just wait to see if problem clears?
EDIT.
I've just made the connection, I've had intermittant crackle on my voice line for the last 4-5 days. I guess this is related to above.
Re: FTTC Issues
01-07-2015 10:08 PM
Re: FTTC Issues
02-07-2015 10:01 AM
The crackle on the line will explain the test result I got back. Unfortunately I can't check for G.INP again until the engineers gone out as we can't test a FTTC line whilst a engineering task is raised.
@jamesanstee
That throughput looks horrible. You should have had the option to run another test after the last one failed which is known as a TAP3 test. That bypasses us and allows you to connect straight to the exchange.
Re: FTTC Issues
02-07-2015 11:00 AM
Re: FTTC Issues
02-07-2015 4:11 PM
Openreach engineer tested line today, no problems found. As it happens everything appears back to normal my end.
I did mention to engineer about the spell of constant disconnects, and he said it's possible someone was changing cards in the exchange at the time.
Will continue to monitor the line my end.
Re: FTTC Issues
09-07-2015 6:57 PM
Fault ticket now raised #107152983
Re: FTTC Issues
14-07-2015 10:41 PM
