FTTC GEA Test
ketleystar
FTTC GEA Test
Hi, could I have GEA Test please for my line
Thank You
4 REPLIES 4
EmilyD
Fixes: 111
Re: FTTC GEA Test
Hi @ketleystar,
Here is your GEA test result. Please let us know if there's anything further that you'd like us to look into.
GEA Test Detail
Circuit ID NA Service ID BBEUXXXXXXXX
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 63.6 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 391.6
Upstream Rate Assessment Very Good
Downstream Rate Assessment Reasonable
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
DP Type External
Profile Name 0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2020-01-24T14:30:00
Parameters MIN MAX AVG
Down Stream Line Rate 56.5 Mbps 63.6 Mbps 60.1 Mbps
Up Stream Line Rate 20.0 Mbps 20.0 Mbps 20.0 Mbps
Up Time 674.0 Sec 900.0 Sec 899.6 Sec
Retrains 0.0 2.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2020-01-31T16:04:43.483+00:00 2020-01-31T16:19:43.483+00:00
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
 Emily D
ketleystar
Re: FTTC GEA Test
Hi could I have GEA Test please as I have changed new dsl cable (shorter one)
TheMightyAJ
Fixes: 105
Re: FTTC GEA Test
Hi @ketleystar,
I've run a GEA Test today and we're practically seeing the same results as before. Are you experiencing any issues with the services from your end of things?
GEA Test Detail
Circuit ID NA Service ID REDACTED
Test Outcome Pass
Sync Status In Sync
Downstream Speed 63.5 Mbps
Estimated Line Length In Metres 377.3
Technology VDSL
DP Type External
Profile Name 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2020-02-07T14:30:00
Down Stream Line Rate 63.1 Mbps 63.5 Mbps 63.2 Mbps
Up Time 840.0 Sec 900.0 Sec 899.8 Sec
Retrains 0.0 1.0 0.0
Start Time Stamp 2020-02-13T13:49:57.340+00:00 2020-02-13T14:04:57.340+00:00
Egress Code Violation 0 1
Errored Seconds 0 0
 Alex H
ketleystar
Re: FTTC GEA Test
Thanks. My mate told me that my cabinet isn't on huawei as I am on ECI cabinet and that's why I got no chance of G.INP enabled but I have asked Bob Pullen to put me on this here: https://community.plus.net/t5/Fibre-Broadband/ECI-Cabinets/m-p/1708105/highlight/true
