FTTC GEA Test
- Re: FTTC GEA Test
FTTC GEA Test
31-01-2020 2:35 AM
Hi, could I have GEA Test please for my line
Thank You
Re: FTTC GEA Test
31-01-2020 4:24 PM - edited 31-01-2020 4:24 PM
Hi @ketleystar,
Here is your GEA test result. Please let us know if there's anything further that you'd like us to look into.
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 63.6 Mbps | ||||
Upstream Speed | 20.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 391.6 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Reasonable | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
DP Type | External | ||||
Profile Name | 0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2020-01-24T14:30:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 56.5 Mbps | 63.6 Mbps | 60.1 Mbps |
Up Stream Line Rate | 20.0 Mbps | 20.0 Mbps | 20.0 Mbps |
Up Time | 674.0 Sec | 900.0 Sec | 899.6 Sec |
Retrains | 0.0 | 2.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2020-01-31T16:04:43.483+00:00 | 2020-01-31T16:19:43.483+00:00 |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Re: FTTC GEA Test
11-02-2020 8:44 AM
Hi could I have GEA Test please as I have changed new dsl cable (shorter one)
Re: FTTC GEA Test
13-02-2020 2:20 PM - edited 13-02-2020 2:23 PM
Hi @ketleystar,
I've run a GEA Test today and we're practically seeing the same results as before. Are you experiencing any issues with the services from your end of things?
Circuit ID | NA | Service ID | REDACTED |
Downstream Speed | 63.5 Mbps | ||||
Estimated Line Length In Metres | 377.3 | ||||
Customer Traffic Level | Upstream and Downstream traffic detected | ||||
Profile Name | 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2020-02-07T14:30:00 |
Down Stream Line Rate | 63.1 Mbps | 63.5 Mbps | 63.2 Mbps |
Up Time | 840.0 Sec | 900.0 Sec | 899.8 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Start Time Stamp | 2020-02-13T13:49:57.340+00:00 | 2020-02-13T14:04:57.340+00:00 |
Egress Code Violation | 0 | 1 |
Re: FTTC GEA Test
18-02-2020 9:51 AM
Thanks. My mate told me that my cabinet isn't on huawei as I am on ECI cabinet and that's why I got no chance of G.INP enabled but I have asked Bob Pullen to put me on this here: https://community.plus.net/t5/Fibre-Broadband/ECI-Cabinets/m-p/1708105/highlight/true
