FTTC Download speed slower since upload speed upgrade
- FTTC Download speed slower since upload speed upgr...
17-11-2017 2:30 PM
I recently received a communication to say that my 40/2 FTTC connection was getting an upgrade to 40/10.
Sounded good. But since that change was rolled out my download bandwidth is now only 3.5MB/sec instead of the normal 4.4MB/sec I get.
How can I get back to my previous download speed?
Re: FTTC Download speed slower since upload speed upgrade
17-11-2017 3:08 PM
Probably the best thing you can do is nothing. The upgrade will have reset the line and probably set the SNR to 6dB. Leave it alone for say a week to see if the DLM automatically winds the SNR down and the speed back up.
17-11-2017 4:38 PM
Same problem. "Good News from Plusnet - Your Fibre Just got Faster" note received. In reality, Upload speed the same, download speed reduced. We are in a rural location, so speeds are slow anyway, but the recent improvement has resulted in download dropping from a little over 5.5 to 4.5 and upload remaining the same, at 1.03. Can I cut my payments by the same %?
22-11-2017 1:03 AM
My connection hasn't sorted itself out still, and I remain on a slower than usual speed.
Are there any guidelines from PN on how long it should take for my line to work out that it can go quicker? I would rather just go back to 40/2 if 40/10 causes slower downloads, I don't really upload anything so had no issue with the 2mbps upload speed I was using.
22-11-2017 1:57 AM
23-11-2017 6:31 PM
Yes I realise that may be the problem, but I have no indication how long that may take to kick in?
I have been on the slower speed for around a week now, it's not the end of the world but it's around 20-25% slower than it used to be, and I'd really like the missing speed back.
