FTPS problem with small files
pauln
Been transferring some files with FTPS single connection (3-50 MB)  normally  get speeds of 3000+ KB/s but in the last month every few files drops to less than 75 KB/s
If I cancel and restart file ( without disconnecting ) it goes back to 3000+ KB/s
Tried
Different  PC
Different Client
Different FTP server
Rebooting router ( moved gate ways from pcn-bng02 to pcn-bng04 )
Is this linked the problems that others have been posting about here ?
Speed tests come back as
http://www.thinkbroadband.com/speedtest/button/1483383479770544455.png
But Youtube now buffers some times,
And my son has issues with COD
MrSilver
Fixes: 9
Re: FTPS problem with small files
could well be, so far not found many other test cases to prove against, put small ftp downloads could be one to add into the test list.
Fixes: 106
What host are you transferring files from if you don't mind me asking?
Andrue
Some network protocols can be horribly inefficient when transferring small files. SMB (the Windows protocol) is one such example - the difference can be quite startling. A hundred 100kB files will take several seconds to transfer. A single 10,000kB file will transfer in fractions of a second.
At a previous job where we were often transferring data from our office to the corporate servers in Minneapolis over a VPN we got into the habit of zipping the files first then transferring the archive. Even with the overhead of zipping/unzipping it was still faster.
https://forums.freenas.org/index.php?threads/slow-cifs-performance-small-files.42990/
pauln
It has worked flawlessly since I joined in 2014 until Nov/Dec 2016
file size is 3-50 MB example
6.29 MB in 1 minute 27 seconds (73.6 KB/s)
Delete file and retry
6.29 MB in 2.38 seconds (3,378.8 KB/s)
I have ignored below 3MB as the transfer is too fast ( the hand shake takes longer )
the 3000 KB/s will be the limit of the server
I cannot reproduce with same file downloaded over and over , it has to be a queue
