FIbre Issues / General Questions
- Re: FIbre Issues / General Questions
09-09-2017 12:53 PM
Hi guys,
Few questions/concerns if I may about my Plusnet Fibre....
1) When ordering, I would have thought Openreach would have come round and upgraded the Master Socket (as happened in my last property). This did not happen and instead I am having to plug my Fibre modem into an ADSL splitter (this doesn't feel right to me and I am concerned this step was missed during the provisioning process).
2) My guaranteed line speed is supposed to be 32Mbps (I have the 40Mbit package) whereas my max line downstream is showing as 24Mbps in my modem config page (I have tried the stock modem supplied and am currently using a TP Link 9980 VDSL modem/router. This worked perfectly at my last address with Plusnet. When I do a speed test it never peaks above 20Mbps. What are the next steps to resolve? Is this related to the above?
3) Lastly, this is more a moan than a question. Why, in 2017 is my upload capped at 2 Mbps? I cant justify upgrading to the next fibre package because my line (apparently) wont go much above 40mbps. I would happily pay a couple of quid etc to just uncap the upload but there is no option to do this in the control panel (rubbish!). If it was made clear the upload was capped I would never have come back to Plusnet. I feel cheated. What are my options to resolve?
09-09-2017 1:09 PM - edited 09-09-2017 1:09 PM
Hello there and welcome to the community.
Fibre installations have been self-install for almost 2 years. This basically means that that engineer would just complete jumpering work a the cabinet to activate the service. You shouldn't have any issues by using a microfilter.
I'd recommend running through the checks here and reporting the fault to us here if things don't improve.
I'm assuming you're on the Unlimited Fibre package.
It's based on the 40/2 wholesale product we've chosen to base the package on.
It's unlikely you'll be able to upgrade to Unlimited Fibre Extra if your estimated speed is below 40mbps.
I'll happily pass your feedback on.
We'd have let you know during the sales signup journey. Did you create your account online or over the phone?
Anoush
09-09-2017 1:24 PM
OK thanks chap, noted about the Master Socket. I will progress the troubleshooting steps and log a fault.
Would I be able to switch over to Plusnet Business Fibre without penalty?
09-09-2017 1:47 PM
