F@ST2704N
- F@ST2704N
F@ST2704N
20-07-2015 8:18 PM
have been having LOTS of problems today started this morning with NO internet ,,,,,, yes i rang PN only on hold 15mins went through the regular tests with no joy agent suspected the new PN router at fault he dispatch me a replacement
so i set up PPOE with the BT modem all was fine for several hours until i turn off the PC ..... when i turn it back on No connection !! after several attempts still no connection , said unable to connect ?? so eventually uninstalled all Connections via device manager , restart install Hey HO it connects , BUT same again after shut down no connection , But decided its a win 10 problem .
Anyhow after getting very frustrated i plug in the PN Fast router and BEHOLD i have internet again ?
So the question about the PN router is , is there a problem with leaving it on causing heat ? to cause disconnects ?? reason is because i never turn mine off is this a know problem ?
Message 1 of 2
(795 Views)
1 REPLY 1
Re: F@ST2704N
20-07-2015 8:31 PM
Quote from: rongtw is there a problem with leaving it on causing heat ? to cause disconnects ??
Pure speculation I would say, I´ve never had a problem with mine disconnecting ever!.
Message 2 of 2
(399 Views)
