Extremely low download speed
alephant
Dear Plusnet support,
I am suddenly experiencing some speed issues with my fibre broadband.
I had a stable connection at max attainable rate since 29 March, then on 15 May the modem disconnected and reconnected with much lower Down Rate. I noticed it only today.
I tried to disconnect and reconnect, but no difference.
Only after powering off the modem completely, and rebooting it, it synced again at the usual rate.
Snippet of the WAN logs below.
13:53:26, 19 May. ( 135.160000) PPPoE is up -​ Down Rate=78120Kbps, Up Rate=19999Kbps; SNR Margin Down=6.0dB, Up=7.3dB
12:35:37, 19 May. (4447687.070000) PPPoE is up -​ Down Rate=6291Kbps, Up Rate=14092Kbps; SNR Margin Down=32.8dB, Up=11.4dB
15:56:04, 15 May. (4114123.850000) PPPoE is up -​ Down Rate=6291Kbps, Up Rate=14092Kbps; SNR Margin Down=28.4dB, Up=10.5dB
15:56:04, 15 May. (4114123.840000) CHAP authentication successful
15:53:51, 15 May. (4113991.350000) PPPoE is down after 68564 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
15:53:48, 15 May. (4113988.550000) PPP LCP Send Termination Request [User request]
01:07:45, 29 Mar. ( 140.050000) WAN operating mode is VDSL
01:07:45, 29 Mar. ( 140.050000) Last WAN operating mode was VDSL
01:07:44, 29 Mar. ( 138.680000) PPP IPCP Receive Configuration ACK
01:07:44, 29 Mar. ( 138.660000) PPP IPCP Send Configuration ACK
01:07:44, 29 Mar. ( 138.660000) PPP IPCP Receive Configuration Request
01:07:43, 29 Mar. ( 138.510000) PPP IPCP Send Configuration Request
01:07:43, 29 Mar. ( 138.500000) PPP IPCP Receive Configuration NAK
01:07:43, 29 Mar. ( 138.490000) PPP IPCP Send Configuration Request
01:07:42, 29 Mar. ( 137.340000) PPPoE is up -​ Down Rate=77971Kbps, Up Rate=19999Kbps; SNR Margin Down=6.0dB, Up=7.3dB
However, the speed (especially download) is extremely low.
Retrieving speedtest.net configuration...
Testing from Plusnet (81.174.2xx.xxx)...
Retrieving speedtest.net server list...
Selecting best server based on ping...
Hosted by Spitfire Network Services (London) [10.56 km]: 181.907 ms
Testing download speed................................................................................
Download: 1.80 Mbit/s
Testing upload speed....................................................................................................
Upload: 11.22 Mbit/s
Is there any problem with the network in my area, maybe?
Thanks and regards
1 REPLY 1
adamwalker
Fixes: 221
Re: Extremely low download speed
Hi there, I've just been looking into this and there does seem to be an external line fault according to tests I've just carried out.
I've just reported it to Openreach and we should be able to update you within the next few days time.
Here's a link to the ticket that I opened on your account: https://www.plus.net/wizard/?p=view_question&id=190311031
Adam
 Adam Walker
