Extender - Netgear
ElizabethS
Extender - Netgear
Previously I used a Netgear Extender in the house (large bunglow) we live in - am wondering if I continue and if so, how difficult would it be to connect this addition ?  ...or do Plusnet, have their own product.
4 REPLIES 4
Fixes: 418
Re: Extender - Netgear
The extender can be used without problems. Just follow the instructions that came with the extender. If you have lost them you will find them on line.
PN do not have their own version.
ElizabethS
Thank you ...will have a go - just dont want to upset the apple cart ...perhaps leave it to when my son visits at Christmas.
Fixes: 418
You won't break anything by having a go. It's probably just the case of pressing the WPS button on the router followed by one on the extender. If you want more help just confirm that the router is a PN Hub One and tell us the model of your extender.
ElizabethS
I’ve managed to do it ...thanks for your help.
