Extemely slow broadband speeds
- Extemely slow broadband speeds
on 02-04-2017 10:32 PM - last edited on 04-04-2017 11:39 AM by Mav
Hi, my broadband speed seems to be really slow lately. See latest speed test (attached). Please can you help.
Moderator's note by Mike (Mav): Changed thread title slightly.
Re: Extemely slow broadband speeds
04-04-2017 11:37 AM - edited 04-04-2017 11:41 AM
Moved to it's own thread by request and title changed slightly
Forum Moderator and Customer
Re: Extremely slow broadband speeds
on 04-04-2017 11:37 AM - last edited on 04-04-2017 11:40 AM by Mav
Testing your line isn't showing any problems, the line is connected back to the cabinet at the full available speed and it's not picking up any problems or errors on the line.
Can you advise if you're testing on a wired or wifi connection?
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0001 | ||||
Description | GEA service test completed and no fault found but unable to check for customer equipment connected to modem. | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 40.0 Mbps | ||||
Upstream Speed | 2.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 568.3 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Very Good | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-40M Downstream, Retransmission Low - 0.128M-2M Upstream, Error Protection Off | ||||
Time Stamp | 2017-03-22T11:45:00 |
