Explanation in layman's terms
- Explanation in layman's terms
on 18-06-2021 1:45 AM - last edited on 18-06-2021 10:26 AM by dvorak
Have reported slow speed on my line, wish to have an explanation in plain English as to what the below means
Broadband Troubleshooter started
Now you've confirmed your contact details and telephone number your broadband is supplied on, we need to ask you some questions about your problem.
We'll save your answers for 14 days, so you can come back if you don't have time to answer everything now.
- Fault start date was added and set to 16-06-2021
- Service affected was added and set to Broadband
- Fault symptom was added and set to Authentication
- Engineer visit was added and set to No
Reason Code: Log Speed Fault
Right to Leave Start Date: 16-06-2021
Right to Leave End Date: 16-07-2021
Thanks for reporting your broadband problem
Our tests have found a fault with your broadband service.
You've given us all the information we need about your problem, we'll raise this to our supplier for investigation.
A Ticket has been raised to our Faults Team to monitor the problem and we'll be in touch when we have an update for you. In the meantime:
- Leave your equipment plugged in and powered up.
- Make sure you've given us a contact number we can reach you on (we'll keep you updated about your problem by text message).
If there's any change to the problem you're having please get in touch with us.
This has now been forwarded to the relevant support team. We will carry on investigating your problem and your open fault will be updated as soon as more information is available.
[INTERNAL]
Ticket now off hold. Please action.
[CSA Removed]
Re: Explanation in layman's terms
18-06-2021 7:53 AM
My reading:
1. You reported a fault as your speed is low on the 16th June.
2. Plusnet tests have confirmed that you have a fault and has passed it to the appropriate team for investigation. They will let you know if there is any progress on fixing it.
3. If the fault fixes itself let Plusnet know.
4. If they can't fix it by the 16th July then you can cancel your Plusnet contract without incurring any cancellation charges.
5. You sent them an additional speed test result yesterday.
18-06-2021 10:10 AM
@Intcomp @Baldrick1 Although the OP indicated a speed fault Plusnet seem to have logged it as an Authentication problem
That doesn't look right to me.
18-06-2021 11:24 AM
Good morning @Intcomp
I'm not sure if you're aware, as the notes on the account do not make it clear, however our Technical Support Team have now identified an issue with your phone line, which has now been raised to our suppliers. The update has been sent to you via Email if you'd like to have a look.
