Everything normal until last week
yogibear
My problem started when i missed a payment and had restrictions on my internet. Made the payment and since then I have had nothing but problems constant issues loading websites (image below), games are showing bad connections etc
I have contacted support who ran a line test but said there was no issues but I am getting fustrated now. It feels like my internet is throttled
8 REPLIES 8
Fixes: 1,600
Re: Everything normal until last week
Our tests aren't showing any issues.
Sync Status In Sync
Downstream Speed 48.5 Mbps
Upstream Speed 11.2 Mbps
Voice Line Test Result Pass
Are your devices connecting over WiFi or straight to the router using an ethernet cable?
yogibear
Mixture but my main device is wired
Fixes: 1,600
Can you run a BT speedtest at http://www.speedtest.btwholesale.com using a wired connection, completing the further diagnostics at the end? This will store the result on the supplier system and will help us in reporting a fault to our suppliers.
yogibear
Done however i got a message at the end, Screenshot
Fixes: 1,600
That message indicates you entered details into the FTTP boxes but you don’t have an FTTP service sadly. Can you try completing the FTTC part instead?
yogibear
It looks like I have managed to resolve this issue with the assistance with a friend who works in the IT industry.
Thanks for your help and cooperation during this time
yogibear
I will monitor over the next few weeks and see if the issue reoccurs
LaurenB
Fixes: 131
Thanks for the update, I hope it's sorted, let us know how you get on Smiley
 Lauren Barry
