Everyday my Internet is disconnected!
- Everyday my Internet is disconnected!
3 weeks ago
Re: Everyday my Internet is disconnected!
3 weeks ago
Is this a Hub One: big blue light on the front?
Is your problem that you are losing connection(s) from phones/terminals/etc. to the Hub, or is the Hub losing connection to the internet?To put that another way: when you have the problems, what light is showing on the Hub?
3 weeks ago
3 weeks ago
Hi @mrshaw14
It sounds like you have a fault.
It is possible that the fault could be with the Openreach line to your house, if the risk is the fault would not be fixed by moving ISP.
Have you reported the fault to Plusnet and have Openreach investigated the issue?
One method of reporting the fault is to follow the steps at:
Regards
Richard
3 weeks ago
2 weeks ago
I've been experiencing exactly the same problem in the last 2 weeks. It's not a WIFI problem, the router light goes from blue to flashing red, usually for a couple of minutes.
I tried 3 different sockets in the house, including the master one, but I'm getting the same problem.
It is pretty annoying, of course as I keep losing connection during meetings
Any help?
2 weeks ago
Just to add to my above post, the connection dropped 5 times in the last 20 minutes...terrible
2 weeks ago
I've just registered here because I have exactly the same problem, at least 5 times a day the line disconnects. It's not Wifi, that remains connected.
Totally unacceptable in 2021 when we're all working and learning remotely!
Been on hold for a while now, hopefully someone will answer the phone and help me!
2 weeks ago
Have the same problem, go through the Plusnet help system and do a line test. Mine has registered a fault, when I plug an old wired phone into the master socket I hear crackling on the line.
Its a typical problem in my location (Cheltenham) as the phone lines are buried in the pavement, the box will fill with water and the connection gets wet.
21st century technology 🤣
2 weeks ago
I've been through the help today and we're having an engineer out. They have identified an issue close to my property so hopefully it can be resolved.
