Everybody around me seems to get 80mb, but i only get 40mb, maybe just location?
- Everybody around me seems to get 80mb, but i only ...
15-05-2015 6:24 PM
i have recently been connected to FTTC fibre and my line profile looking on the BTW test site is roughly 40 mb down and 20 mb up and i actually get 38 mb down and about 7 mb up and i am on the standard plusnet fibre package as the extra couldn't guarantee better than 40 mb, so understood.
My first question is, if i upgraded to extra, would i see the 20 mb upload?
Looking at the attached clip from google earth, when i run the 'what can i expect' test on the Bt website, all my firends shown can get 80/20, where mine can only achieve the 40 mb D/L.
Do i have a potential problem or is it just the case of location as there may be more than one fibre cable serving all of us.
Any thoughts would be much appreciated
Re: Everybody around me seems to get 80mb, but i only get 40mb, maybe just location?
15-05-2015 7:48 PM
it might help if you can run the bt wholesale speed test and post the results http://www.plus.net/support/broadband/bbfaults/bt_speed_tester.shtml
15-05-2015 7:53 PM
15-05-2015 8:47 PM
Anyway, i have run the BTW speedtest and results attached. it does show as 20 mb is maximum but only achieves 6 mb, is this because i am on the standard package?
What is a little strange is my friend near the cabinet is still 80/20.
my other friend across the field from me is now only showing he can get ADSL2+ and is served by a different cabinet and the same when i check on the BT website.
My other friend who is with talktalk cant even be tested so i am guessing my earlier results i got from the BT website were rogue.
It does seem odd that my friend who is 100 yards up the road is getting double what i get. when we were both on ADSL2+, he would get 16 mb and i would get around 12 mb.
Anyway, thanks very much for the input.
15-05-2015 9:53 PM
http://www.increasebroadbandspeed.co.uk/2012/graph-ADSL-speed-versus-distance
The table on the above page would estimate your line to be around 2.5km (from the exchange) vs 2km for your friend and that leads to a corresponding drop in VDSL performance
http://www.increasebroadbandspeed.co.uk/2013/chart-bt-fttc-vdsl2-speed-against-distance
The table on the above page would suggest that your friend is between 200m and 300m from the cabinet and you are between 700m and 800m. I make no claim for the accuracy of the tables of course but they do show a consistent order of magnitude difference...
15-05-2015 10:25 PM
I am 200m from my cabinet walking distance, but line is nearer 400m in length.
Due to high crosstalk severity, you probably need to be under 200m to be reasonably confident of a solid long lasting 80meg sync. Above that its still very possible but crosstalk will drag it down.
15-05-2015 11:02 PM
Now the other two addresses are not showing the 80/20, it makes it more understandable as it seemed that everyone around was getting the maximum.
Another 5 years for FTP, not that i need it really, just one of those things that was bugging me
Why does my line profile show maximum achievable upload as 20 mb but achieves on 6 mb ?
thanks
15-05-2015 11:09 PM
15-05-2015 11:14 PM
That is not to say that it cannot be improved, but a product change won't do that.
15-05-2015 11:25 PM
16-05-2015 9:08 AM
We're on the 40 Mbps package & get 38 Mbps but we get at least 15 Mbps upload.
16-05-2015 9:34 AM
thanks
And here it is, not much help though although i will try connecting to the master socket and also my issued modem and router for a while
http://community.plus.net/forum/index.php/topic,103856.msg883652.html#msg883652
16-05-2015 10:01 AM
16-05-2015 10:06 AM
16-05-2015 5:19 PM
VDSL2 is very adaptive and will pretty much squeeze all the speed it can get from the line. Barring some line fault, your speed stats are not uncommon.
