Evening Slowness
Evening Slowness
Do Plusnet throttle connections in the evening?
I notice a lot more buffering compared to the day time on some filesharing/streaming services.
Speedtests come back about the same as during the day but they could prioritise traffic to these sites.
1 REPLY 1
Fixes: 6
Re: Evening Slowness
Quote from: mitch0
That depends which package you are on, some of the older products did throttle certain types of usage at peak times.
If you are on the current 'unlimited' package, then that has no traffic throttling and all usage should run at your line speed.
Quote from: mitch0
That could be due to exchange congestion if BT has capacity issues.
It could also be your phone line or internal wiring being prone to increased noise during the hours of darkness, causing data errors - which would show up as reduced speed.
Quote from: mitch0
If they did, then someone here would have noticed by now.
Wink
Plusnet FTTC 80/20 IPv4/30, Hurricane Electric 6in4 IPv6/48, Pulse8 landline & calls, SamKnows 600N
Vigor 130 modem, pfSense 2.4.5-p1 router, 5 WAPs, Devolo dLAN 500, Gigaset N300A-IP VoIP DECT
