Estimating speed increase of Fibre Extra
ashn
I'm currently using John Lewis standard fibre (i.e. "provided by Plusnet"), where I get 40mbit sync. I'm looking at switching to Plusnet Fibre Extra, and the estimated speed shown when putting in my details is 36mbit to 52mbit. Is there any other way of getting an idea of what it might be, without signing up to a lengthy contract?
When I was on ADSL, my actual speeds were significantly higher than the estimate, but I don't know if it works a lot differently on fibre, or if any of my line sync statistics might give an indication.
Thanks for any advice!
1 REPLY 1
Beyhive
Fixes: 43
Re: Estimating speed increase of Fibre Extra
Hi @ashn,
You can click here to find the maximum speeds you can get by choosing the Plusnet Fibre Extra.
I would recommend you speak to the Sales team who will be able to tell you the speed estimates before signing up. You can contact them as per the following contact information below:
Telephone number:
0800 013 2632
Opening Times:
08:00 - 20:00 Monday to Friday
09:00 - 19:00 Saturday
09:00 - 18:00 Sundays
I hope this helps.
 Faris
