Error 1062
ddsabre2011
Error 1062
Sorry if this is a repost but i couldnt find anything about error 1062 anywhere on the forum. I get this when trying to setup a new connection when hooked up directly to the open reach modem for testing purpose. Has anybody else had this error and how did you go about solving it?
Thanks.
1 REPLY
AshPowell
Re: Error 1062
Click the start menu and search for services.msc, open that then look for Remote Access Connection Manager and start it.. hopefully should sort the problem
