English please
riky
English please
Hi can anyone tell an oldy like myself what this means ???????????????
Connection online and stable
Sync speeds below estimates but above MGALS
No issue with profile
Will discuss as only option will be SFI if EU wants to improve
23 REPLIES 23
Legend
Fixes: 255
Re: English please
Your connection is online and stable - self explanatory?
Your connection speed is below what the automated system thinks is achievable, but above the Minimum Guaranteed Access Line Speed
Your connection profile is correct
PN will discuss your options with you as it will be necessary to arrange a Specialist Fault Investigator (OpenReach) if you (the End User) wants to improve your connection.
HTH
198kHz
Fixes: 41
Re: English please
Sync speeds:  Speeds at which router connects with exchange
MGALS:  Minimum Guaranteed Access Line Speed
SFI:  Special Faults Investigation
EU:  End user ie you.
EDIT - @jab1  types faster!
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
Fixes: 419
Re: English please
@riky
My guess is that this is an internal Plusnet message recording testing done so far.
Your speed is below the estimated minimum but above the minimum guaranteed access speed. That's the speed below which you can leave without penalties.
The only thing that can be done is to sent out a BT special fault investigator if you want an improvement.
Hopefully a Plusnet staffer will pick this up for you. You will need to make sure that you do or have done internal checks before proceeding down that path to make sire that you don't get caught with a £65 charge.
Edit.
And both @198kHz  and @jab1  are faster than me!
riky
Re: English please
Thanks to all for the answers
The first bit I did guess
It was the SFI and EU that had me stumped
The engineers have already been out 3 or 4 times and found no problems.
My guess is they just cant supply the speeds they promised 2 years ago.
MatthewWheeler
Fixes: 479
Re: English please
Thanks for your post @riky
I can see you've already been provided with explanations of the acronyms above.
With regards to your speed issues, it appears that your speeds may be currently restricted by DLM. I can see my colleague sent a request off for this to be removed and this can take 24 to 48 working hours to go through.
If you haven't seen an increase by Monday let us know
 Matthew Wheeler
riky
Re: English please
@MatthewWheeler
Just checked from within the router admin this morning and I copied the speed below.
DSL Line Status
Connection Information
Line state:
Connected
Connection time: 0 days, 12:55:24
Downstream: 23.72 Mbps
Upstream: 5.778 Mbps
A vast improvement. 😁
Lets hope it stays there this time 😳
Riky
Beyhive
Fixes: 44
Re: English please
Let us know if anything changes @riky, Smiley
 Faris
riky
Re: English please
Update Christmas eve of all the times.
The line speed has dropped and I have copied and pasted the results from within the router admin below
DSL Line Status
Line state:Connected
Connection time:0 days, 00:15:49
Downstream:19.14 Mbps
Upstream:5.691 Mbps
This has dropped from over 23 Mbs
also the new router you supplied me with is not working properly.
the new router shows I am only getting a throughput speed of 9 Mbs
Borrowed my friends router and I am getting 17 Mbs throughput speed according to the OOkla speedtest.
Although the router admin still stays the same
Done the normal testing at my end.
What do you see at your end?
adamwalker
Fixes: 221
Re: English please
Line tests show that the line is syncing at 19.9mbps which is in-line with your router stats more or less.
Were the tests you ran over a wired or a wireless connection? If you haven't done so already please run a test over a wired connection to the router if that's possible just so we can see how the speeds compare to those achieved over WiFi.
Adam
 Adam Walker
riky
Re: English please
Line tests show 19.9 but was showing 23.31
Run the tests again this time using bts speedtest.
Wired and wireless very little difference (both disgusting)
Upload not far of same as download
Results below.
BT Wholesale Broadband Performance Test
Broadband Speed Test Results (Wired)
Download Speed (Mbps): 8.62
Upload Speed (Mbps) : 5.25
Ping Latency (ms): 13
BT Wholesale Broadband Performance Test (Wireless)
Download Speed (Mbps): 7.65
Upload Speed (Mbps) : 5.16
Apart from the line speed drop. Im sure that it can only be the router.
adamwalker
Fixes: 221
Re: English please
Thanks for giving that a try, I'd personally cast doubt on it being the router as we've replaced that recently.
Given that the speeds over a wired connection are well below estimates it would be a good idea to report a new fault with us next: http://faults.plus.net
Please let us know when you have and I'll get that reported for you.
 Adam Walker
riky
Re: English please
Hi Adamwalker
I borrowed the other router again yesterday and the results were as expected 19.14 line speed.16.90 Ookla speedtest.
So after searching through network connections and anything I could find I thought might remotely cause the problem and low and behold after plugging it back in it did an Ookla speedtest and got 16.67
Feeling chuffed that I might have sorted it even though I did not alter anything only to find this morning the router had the same line speed but the throughput speed had dropped back down to 9Mbs.
So still having the borrowed router I have put that back on, Reconnected my wireless items done a speedtest and it is showing 17 Mbs with Ookla only 15.90Mbs with the bt speedtest though.
So I will leave it connected to this router for a couple of days to see how it goes.
But if it stays at this it can only point to the new router going belly up on me.
By the way last time I had low speed it was because of line restrictions? DLM which once removed sorted the speed problem.
EmilyD
Fixes: 117
Re: English please
Hi @riky,
Thank you for letting us know that your connection speed has improved now that you have connected a different router. It may well be the case that your Plusnet router is faulty and has caused the connection problems. Please let us know how your connection performs over the next few days - if the speed continues to stay good with the borrowed router, we can arrange to send you a replacement router from here.
I can confirm that DLM isn't restricting your line's speed in this case.
 Emily D
riky
Re: English please
Hi EmilyD
The speeds are still at 19.14 line speed and 17.00 Throughput speed this morning.
But if it is not the DML that is causing the slowdown (Post 7) showed 23.74 after it was removed last time then what do you suspect it may be.
