English please
riky
English please
Hi can anyone tell an oldy like myself what this means ???????????????
Connection online and stable
Sync speeds below estimates but above MGALS
No issue with profile
Will discuss as only option will be SFI if EU wants to improve
7 REPLIES 7
Fixes: 19
Re: English please
Your connection is online and stable - self explanatory?
Your connection speed is below what the automated system thinks is achievable, but above the Minimum Guaranteed Access Line Speed
Your connection profile is correct
PN will discuss your options with you as it will be necessary to arrange a Specialist Fault Investigator (OpenReach) if you (the End User) wants to improve your connection.
HTH
198kHz
Aspiring Hero
Fixes: 16
Re: English please
Sync speeds:  Speeds at which router connects with exchange
MGALS:  Minimum Guaranteed Access Line Speed
SFI:  Special Faults Investigation
EU:  End user ie you.
EDIT - @jab1  types faster!
To err is human, but to really foul things up requires a forum upgrade.
Fixes: 99
Re: English please
@riky
My guess is that this is an internal Plusnet message recording testing done so far.
Your speed is below the estimated minimum but above the minimum guaranteed access speed. That's the speed below which you can leave without penalties.
The only thing that can be done is to sent out a BT special fault investigator if you want an improvement.
Hopefully a Plusnet staffer will pick this up for you. You will need to make sure that you do or have done internal checks before proceeding down that path to make sire that you don't get caught with a £65 charge.
Edit.
And both @198kHz  and @jab1  are faster than me!
riky
Re: English please
Thanks to all for the answers
The first bit I did guess
It was the SFI and EU that had me stumped
The engineers have already been out 3 or 4 times and found no problems.
My guess is they just cant supply the speeds they promised 2 years ago.
Fixes: 294
Re: English please
Thanks for your post @riky
I can see you've already been provided with explanations of the acronyms above.
With regards to your speed issues, it appears that your speeds may be currently restricted by DLM. I can see my colleague sent a request off for this to be removed and this can take 24 to 48 working hours to go through.
If you haven't seen an increase by Monday let us know
 Matthew Wheeler
riky
Re: English please
@MatthewWheeler
Just checked from within the router admin this morning and I copied the speed below.
DSL Line Status
Connection Information
Line state:
Connected
Connection time: 0 days, 12:55:24
Downstream: 23.72 Mbps
Upstream: 5.778 Mbps
A vast improvement. 😁
Lets hope it stays there this time 😳
Riky
Fixes: 32
Re: English please
Let us know if anything changes @riky, Smiley
 Faris
