Engineer needed for install?
FIXED- Subscribe to RSS Feed
- Engineer needed for install?
10-10-2017 12:45 PM
We are in the process of changing to Plusnet Fibre from Talktalk regular ADSL. We've been given an install date of 1 Nov (a lot more than 10 days away!) and I've received 2 text messages, one saying the switch will take place any time before 12 midnight and the other saying between 8am and 1pm. Does this second text mean an engineer will have to attend our premises? I can't seem to find any info whether this is the case. Bear in mind we've never had fibre before....
Rob
Fixed! Go to the fix.
Re: Engineer needed for install?
10-10-2017 1:21 PM
....I've also just had a message from Talktalk that our services will be moving from them on the 24th October. So eight days without internet or phone? Is that right?
R
10-10-2017 2:50 PM
Have you committed the cardinal sin ot telling Talk Talk that you are leaving rather than leave it to Plusnet to arrange to take over the line?
10-10-2017 2:57 PM
Nope. We let Plusnet do it. The message from TalkTalk said 'We've received a request from another provider that you'll be moving your TalkTalk services over to them on 24th October 2017.' We got this just after the message from Plusnet saying 'Your fibre appointment is booked for 1st November 2017 between 8am - 1pm'. Sounds like a bit of a mess to me.....
10-10-2017 2:58 PM
An engineer doesn't have to attend your premises but does need to do work at the cabinet (and possibly the Exchange). Hence it can be anytime during the day.
If you put your phone number in here there may well be a narrative about an "Open Order"
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
10-10-2017 3:17 PM
Thanks Brian, our number gives 'There is no data available for this number.' for a result at the moment. I'm seeing some contradictory advice on the forums, but the consensus seems to be if you're a new customer you will self-install but swapping from existing Plusnet ADSL you will need a home visit. Is that right? I don't know if this is to fit a filtered faceplate to the master socket or what, but it's always nice to know; I think the days of hubby out to work while his fragrant wife is constantly home minding the kids and doing the housework are well gone, and this will take a bit of arranging - see also home deliveries!
R
10-10-2017 3:19 PM
....and this also doesn't help with the eight days of disconnection problem.
10-10-2017 3:38 PM - edited 10-10-2017 3:39 PM
That can happen when there's stuff going on behind the scenes. Pity, as it tends to give the date any open order is expected to complete.
House visits are not required for FTTC installations (unless a problems has been identified beforehand). You simply plug the supplied filter into the phone socket.
For a move from ADSL to VDSL an engineer is required to "connect" your phone line from your cabinet to the fibre cabinet. I'm not certain about if any work is required at the Exchange.
Can't help with order dates.
10-10-2017 4:01 PM
Thanks guys, very helpful. Now to try to speak with a Plusnet representative and see if we can push those two dates a little closer together!
R
11-10-2017 4:08 PM
Hi Rob,
The original required by date was the 24th October but the order was delayed by Openreach to the 1st November.
As we're taking over an active service, I wouldn't expect you to be without service [except for a few hours on the day], so it's possibly just a case of that your previous provider hasn't comm'ed out the new transfer date to you.
FYI there's no engineer visit required to your property, apologies for the confusion caused.
I hope this helps
Anoush
11-10-2017 8:41 PM
Thanks again.
Rob
12-10-2017 11:29 AM
