Engineer just been and repaired line but still something is up.
- Re: Engineer just been and repaired line but still...
on 12-06-2018 11:21 AM - last edited on 12-06-2018 7:10 PM by Mav
Hey All,
I've recently been experiencing broadband issues and banding on my line. I've had an engineer visit and repair the fault and my line is now showing a much higher sync rate but my download speeds are still very slow? I'm plugged into the router via a pair of bonded cat6 cables. Here is my data.
Actual download speed: 2.7MB/s
Speed test results:
Retrieving speedtest.net configuration...
Testing from Plusnet (80.229.xxx.xxx)...
Retrieving speedtest.net server list...
Selecting best server based on ping...
Hosted by Structured Communications (London) [2.56 km]: 16.373 ms
Testing download speed................................................................................
Download: 21.82 Mbit/s
Testing upload speed......................................................................................................
Upload: 13.00 Mbit/s
Sync status (see attachments)
VDSL status:
---------------------- ATU-R Info (hw: annex A, f/w: annex A/B/C) -----------
Running Mode : 17A State : SHOWTIME
DS Actual Rate : 43546000 bps US Actual Rate : 14124000 bps
DS Attainable Rate : 43064232 bps US Attainable Rate : 14177280 bps
DS Path Mode : Fast US Path Mode : Fast
DS Interleave Depth : 1 US Interleave Depth : 1
NE Current Attenuation : 20 dB Cur SNR Margin : 4 dB
DS actual PSD : 6. 7 dB US actual PSD : 6. 9 dB
NE CRC Count : 11 FE CRC Count : 12590
NE ES Count : 10 FE ES Count : 2685
Xdsl Reset Times : 0 Xdsl Link Times : 2
ITU Version[0] : 00000000 ITU Version[1] : 00000000
VDSL Firmware Version : 07-07-09-05-01-07 [with Vectoring support]
Power Management Mode : DSL_G997_PMS_L0
Test Mode : DISABLE
-------------------------------- ATU-C Info ---------------------------------
Far Current Attenuation : 26 dB Far SNR Margin : 6 dB
CO ITU Version[0] : b5004946 CO ITU Version[1] : 544eb206
DSLAM CHIPSET VENDOR : < IFTN >
VDSL status more:
Near End Far End Note
Trellis : 1 1
Bitswap : 0 1
ReTxEnable : 0 0
VirtualNoise : 0 0
20BitSupport : 0 0
LatencyPath : 0 0
LOS : 2 0
LOF : 0 0
LPR : 0 0
LOM : 0 0
SosSuccess : 0 0
NCD : 0 0
LCD : 0 0
FECS : 155 1133480 (seconds)
ES : 10 2685 (seconds)
SES : 0 106 (seconds)
LOSS : 0 1329 (seconds)
UAS : 43 95119 (seconds)
HECError : 0 0
CRC : 12 12590
INP : 0 0 (symbols)
INTLVDelay : 0 0 (1/100 ms)
NFEC : 255 255
RFEC : 16 16
LSYMB : 3788 11671
INTLVBLOCK : 255 255
AELEM : 0 ----
Router: Draytek Vigor 2682
SNR Margin delta: -10
Hardware Accel: True
Throughput:
1 192.168.1.43 496 23074 527 Block NoneClass 1Class 2Class 3Default
2 192.168.1.16 --- --- 1 Block NoneClass 1Class 2Class 3Default
3 192.168.1.100 --- --- 1 Block NoneClass 1Class 2Class 3Default
Any ideas? If I was a betting man I'd say I'm still banded at the exchange even though there was a DLM reset?
Moderator's note by Mike (Mav): Post released from Spam Filter.
Moderator's note by Mike (Mav): Personal information (IP) removed from a public forum (to an area that staff can see).
Re: Engineer just been and repaired line but still something is up.
21-06-2018 10:53 AM
Hi there.
Apologies for the delayed response.
It looks like the profile rate on our side was still reflecting the slow sync rate and was capping your throughput. I can see shortly after you made this post you contacted us over web chat and we made the necessary adjustments.
Everything working now as you'd expect?
