Engineer been and gone.. Activate me please?
theoneandonly
Hi there. This morning a BT engineer came by and did everything they need to do successfully. I've since seen the router connect to broadband and it has a blue light. I've made sure it is connected via the router admin too, and though I seem to be able connect I can only access Plus.net domain pages.
The BT engineer told me I'll still be waiting for you guys to activate me, and it can happen anything from 15 mins after he's done his job here. He also said it is meant to be the same day that you connect me.
I can see other forum posts from people in the same situation where they need connecting... can you connect me?
Tags (3)
Fixes: 238
Re: Engineer been and gone.. Activate me please?
If you can PM me your username I'll get it looked into.
 Matthew Wheeler
Fixes: 167
Don't worry about sending Matthew a PM. I've found your account, the order has now completed and I'm activating it now.
 Chris Parr
 Plusnet Staff
theoneandonly
Thanks!
