EdgeRouter not getting the right static IP
- EdgeRouter not getting the right static IP
20-03-2016 9:05 PM
I have been using my EdgeRouter Lite for a couple of months without any problems but about two weeks ago after a reboot of the OpenReach box it won't get the right IP anymore. I paid for the static IP service when I signed up and it has worked flawlessly all this time with both, the Plusnet router and the EdgeRouter.
What I can see in the pppoe logs is that I'm getting a the wrong IP. My static IP is 213.1.102.XXX and I get a ConfNAK if I explicitly set the EdgeRouter config with it:
sent [CHAP Response id=0x1 <249930aa0d49fa1f2e916e2fde5038b6>, name = "username"]
rcvd [LCP EchoRep id=0x0 magic=0x3bd89f18]
rcvd [CHAP Success id=0x1 "CHAP authentication success, unit 9576"]
CHAP authentication succeeded: CHAP authentication success, unit 9576
peer from calling number 00:30:88:00:00:0A authorized
sent [IPCP ConfReq id=0x1 <addr 212.159.XXX.XXX> <ms-dns1 0.0.0.0> <ms-dns3 0.0.0.0>]
rcvd [IPCP ConfReq id=0x53 <addr 213.1.102.1>]
ipcp: returning Configure-ACK
sent [IPCP ConfAck id=0x53 <addr 213.1.102.1>]
rcvd [IPCP ConfNak id=0x1 <addr 172.16.144.84> <ms-dns1 62.6.38.125> <ms-dns3 62.6.38.125>]
sent [IPCP ConfReq id=0x2 <addr 172.16.144.84> <ms-dns1 62.6.38.125> <ms-dns3 62.6.38.125>]
rcvd [IPCP ConfAck id=0x2 <addr 172.16.144.84> <ms-dns1 62.6.38.125> <ms-dns3 62.6.38.125>]
And if I don't specify it it's the same but without the ConfNak. I've never had to specify it when it used to work.
Any insights?
Thanks.
Ramon
Re: EdgeRouter not getting the right static IP
20-03-2016 9:19 PM
[Edit] Having re-read your post, and doing a nslookup on the 212.159.xxx.xxx address, it's possible that Plusnet have changed your IP address for some reason?
20-03-2016 9:57 PM
Internet is not working after the successful PPPOE CHAP authentication. The IP 212.159.XXX.XXX hasn't changed as with the Plusnet router my connection works (I'm writing this with it right now). The internal 172.16.XX.XX is the problem, I should be getting the 212.159.XXX.XXX as I used to but I'm not.
This all started after I had to restart my OpenReach box and after that the EdgeRouter got the 172.16.XXX.XXX for the first time and it hasn't got the right static IP any longer.
Cheers.
20-03-2016 10:17 PM
You're being offered a 212.159.xxx.xxx address (you might want to edit the full address in your original post) when you use the PN router? This address therefore is the address that PN have assigned to you so where does 213.1.102.xxx come into it? The 212.159.xxx.xxx address resolves to a host name that looks like it may be yours? [You may want PN to change the reverse DNS for this by the way]
The EdgeRouter log seems to show that it is also, as expected, being assigned the 212.159.xxx.xxx address but you're then trying to force the router to use the 213.1.102.xxx address so the BT Wholesale system is returning a BT private address?
21-03-2016 7:41 AM
The way the Plusnet system works is that you will be assigned the same IP address each time you connect.
If you go to https://portal.plus.net/my.html?action=myconnection&?membermenu=connectionsettings you should have an icon that looks like this:
which will tell you if your fixed IP is still configured correctly and what it should be.
21-03-2016 8:13 AM
21-03-2016 8:40 AM
The log shows that authentication is OK and a PN address is received...
An obvious change is the connection dropped and was reestablished and I suspect that this meant that the changed static IP was picked up. Note the address that the OP had was in a BT allocation so this may be mixed up with the PN network changes?
21-03-2016 10:51 AM
1. Username and password are sent and authenticated. If I use the username@plusdsl.net as suggested, the authentication will fail:
2. Initially I hadn't specified my static IP and as explained by jelv I always got the correct IP address. The logs below is from whenI tried specifying the local IP with my static IP 212.159.XXX.XXX when it started failing but it doesn't work as you can see:
2.1 The router tries to specify IP that I set in the config and it leaves the DNS servers for the DHCP server to set:
2.2 The plusnet server gives back the PPPoE peer IP 213.1.102.1 and the EdgeRouter acknowledges setting it up. Note that this is the IP at the other end of the PPP connection:
2.3 I think this means that the IP sent by the EdgeRouter (212.159.XXX.XXX) is not accepted:
2.4 Finally the IP requested by the Plusnet end is configured locally instead of the 212.159.XXX.XXX which is the one that works with the Plusnet router and used to work with the EdgeRouter:
I don't believe static IP addresses are based on the MAC address of the router but rather on the username and password but if that was the case an additional test I could do is setting the MAC address of the Plusnet router in the EdgeRouter.
Thanks again for all of your suggestions.
21-03-2016 11:35 AM
Quote from: racplus Thanks for all the suggestions. Analysing the log here to help with your insights:
We're seeing 'password incorrect errors hitting our RADIUS server. If the username was incorrect then it wouldn't show anything.
Quote from: racplus 2. Initially I hadn't specified my static IP and as explained by jelv I always got the correct IP address. The logs below is from whenI tried specifying the local IP with my static IP 212.159.XXX.XXX when it started failing but it doesn't work as you can see:
Although you are assigned the same IP address each time, this is actually still from a pool of IPs allocated as dynamic but just gives you the same one each time. You shouldn't try to set it as a static IP on your router.
Quote from: racplus 2.2 The plusnet server gives back the PPPoE peer IP 213.1.102.1 and the EdgeRouter acknowledges setting it up. Note that this is the IP at the other end of the PPP connection:
Every single one of your connections that's made it to our RADIUS is using your static IP, there are no other connections using anything but this.
Quote from: racplus I don't believe static IP addresses are based on the MAC address of the router but rather on the username and password but if that was the case an additional test I could do is setting the MAC address of the Plusnet router in the EdgeRouter.
Correct, it's not based on the MAC address of the hardware, but on the authentication details.
25-03-2016 7:15 PM
Quote from: Chris
In the end, the problem was using the wrong password and as the logs only complained when I added the "@plusdsl.net" and showed a successful authentication without it (even with the wrong password) it was misleading. The fact that you saw in your RADIUS password incorrect errors gave me the tip.
Many thanks.
