Early activation
Darzomc
Early activation
Hi would it be possible to get activated asap or do I have to wait until the date I was given?Huh
Fixes: 79
Re: Early activation
Hi, we can activate accounts early if the router is showing as in sync (receiving the broadband signal from the exchange)
 Adam Walker
Darzomc
Hown do I know that it is receiving the connection?
The light at the front of the router is orange and under it there is a "b" lit up red....
Fixes: 106
If you log into the router interface here, then navigate to troubleshooting > helpdesk, then it will give you a fairly good idea. If the line is in sync then you will see a connection rate there (under 'bandwidth' I think).
Darzomc
Hi
The router is showing that it is in sync. Could you please activate it please asap?
Darzomc
Could you let me know if it could be activated today
etdsaunders
Fixes: 7
Try live chat, might get a faster reply.
Raspberry Pi enthusiast!
If you Like it, give it a Thumbs Up
MattyC
Champion
Fixes: 46
I've just activated you. Are you ok to let me know if you can get online?
Darzomc
hi
i am currently at work
i will let you know within an hours time
thanks
MattyC
Champion
Fixes: 46
Thanks @Darzomc
