EE Signal Box
- Re: EE Signal Box
EE Signal Box
11-07-2015 4:04 PM
Anyone wanting to use an EE signal Box on a plus net fibre connection via a BT Openreach fibre handover box will prob find it wont work
To get around this problem I disconnected the plus net router and openreach box and replaced them with a BT Homehub 5 (the cable which previously went into the openreach box goes to the homehub )
all you need to do is enter your credentials into the new homehub and it will se itself up then connect the signal box to the home hub it will register itself and be working in minutes
I do not understand why plusnet use a router and an openreach box when there are routers capable of doing the job without all the extra boxes and wiring
Message 1 of 4
(1,423 Views)
3 REPLIES 3
Re: EE Signal Box
11-07-2015 8:45 PM
My EE signal box works fine on Plusnet FTTC with Openreach modem + Plusnet router.
Message 2 of 4
(979 Views)
Re: EE Signal Box
11-07-2015 8:50 PM
Off topic but how did you manage to get a signal box off EE? I get almost no service in the house but haven't managed to get one, been using Wifi Calling but it's a bit iffy at times.
Message 3 of 4
(979 Views)
Re: EE Signal Box
11-07-2015 9:09 PM
They gave me mine when there was a fault in the area which they were struggling to fix.
Message 4 of 4
(979 Views)
