ECI Openreach modem use
- ECI Openreach modem use
30-11-2015 5:29 PM
Hi i am looking to upgrade to FTTC with plusnet and my use will be gaming, i recently purchased a 150 pound gaming router which i will use to apply features to my gaming experience and as such i need a 3rd party modem.
Iv purchased a cheap openreach modem its the ECI version ( B-focus v-2fub/r Rev B) but i dont seem to be able to access any Web GUI to be able to apply credentials once i am connected up with my order
Has anyone had a similar experience and how did you get your openreach modem configured please?
Message 1 of 3
(1,162 Views)
2 REPLIES 2
Re: ECI Openreach modem use
30-11-2015 5:41 PM
There's nothing to configure on the modem. Your credentials go in the router. You need to configure the WAN connection on the router for a PPPoE connection with your PlusNet username & password.
Message 2 of 3
(873 Views)
30-11-2015 8:03 PM
Ok so these are just plug and play then
Message 3 of 3
(873 Views)
