ECI Cabinets
FIXED- Subscribe to RSS Feed
- ECI Cabinets
- « Previous
- Next »
Re: ECI Cabinets
28-08-2020 5:18 PM
I have not lost it yet either. I have the same as you on the BTW DSL top speed achievable has drop from 42Mbps to 32Mbps, my speed was always near the bottom of the range though.
Re: ECI Cabinets
01-09-2020 9:09 AM
Seems stable and happy with that.
Re: ECI Cabinets
01-09-2020 7:28 PM
Still active on my line too and like dvorak a 3db target snr also seems to have been introduced.
The line resynced a couple of times in the AM of 26/8 when it changed and so far it is holding with a bit of margin to spare although a quick speed test seems to be a bit lower than I would expect for max sync - BT IP profile is fine so I wonder if the plusnet line profile is still a thing for static IPs? I know the display page for it was removed from the portal at some point and although I see something now shown in the member centre under broadband I wonder if that is the same thing?
Re: ECI Cabinets
01-09-2020 8:53 PM
If you have a static IP then yes the Plusnet Profile is still a thing as they still use part of the old network for static where they don't for dynamic those don't use the Plusnet profile anymore.
Re: ECI Cabinets
09-09-2020 5:09 PM - edited 09-09-2020 5:11 PM
Needed to reboot everything today and it looks like my SNR target is back up to 6db after holding steady at 3 since my last post.
I have seen the 3db margin before when the whole area had a power cut (including the cabs) so perhaps it was just a glitch or a firmware update on the cabinet that needed a restart and triggered it. G.INP still active on the line and working fine so no issues other than that.
Re: ECI Cabinets
09-09-2020 8:06 PM
Nice whilst it lasted...
Re: ECI Cabinets
14-09-2020 11:56 AM
Reckon we've gone passed a half year of trials.
G.INP is still enabled even after a few modem reboots.
All figures are downstream only and in Mbps.
Unusually SNR still increases at approx 12-1am up to 6.5 and back down about 7-8am to 4.5.
Max rate increases from 66 up to 72 and back to 66. Increases and decreases are in line with SNR changes.
Connection rate remains constant at 66.56
BT IP Profile remains constant 64.36, device speed 57.
No errors, just a very stable line....
Re: ECI Cabinets
13-02-2021 9:26 AM
Just wondering if anyone else has had G.INP removed from there line?
Re: ECI Cabinets
13-02-2021 9:51 AM
Re: ECI Cabinets
13-02-2021 10:16 AM
333rd day & still enabled.....
Stats recorded 13 Feb 2021 10:08:03
DSLAM type / SW version: IFTN:0xb206 (178.6) / v0xb206
Modem/router firmware: AnnexA version - A2pv6F039t.d26d
DSL mode: VDSL2 Profile 17a
Status: Showtime
Uptime: 1 hour 36 min 8 sec
Resyncs: 1 (since 12 Feb 2021 10:53:55)
Downstream Upstream
Line attenuation (dB): 15.4 0.0
Signal attenuation (dB): Not available on VDSL2
Connection speed (kbps): 70521 20000
SNR margin (dB): 4.1 3.4
Power (dBm): 5.9 5.9
Interleave depth: 1 1
INP: 49.00 0
G.INP: Enabled Not enabled
Vectoring status: 5 (VECT_UNCONFIGURED)
RSCorr/RS (%): 0.0002 0.0016
RSUnCorr/RS (%): 0.0000 0.0000
ES/hour: 0 0.10
Re: ECI Cabinets
13-02-2021 12:00 PM
@Kossack2003 shame coz my line was rock solid with G.INP enabled….😪
@Champnet good to see G.INP is still active for you 🖕
Re: ECI Cabinets
13-02-2021 1:03 PM
It’s not to much of an issue as I should be able to order FTTP by the end of March so I will have to see how much it’s going to cost to get out of my contract as I will have four months left.
Re: ECI Cabinets
13-02-2021 7:23 PM
Still enabled:
Bearer: 0, Upstream rate = 19286 Kbps, Downstream rate = 56861 Kbps Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps Link Power State: L0 Mode: VDSL2 Annex B VDSL2 Profile: Profile 17a TPS-TC: PTM Mode(0x0) Trellis: U:ON /D:ON Line Status: No Defect Training Status: Showtime Down Up SNR (dB): 6.4 7.0 Attn(dB): 13.6 0.0 Pwr(dBm): 13.8 6.4 VDSL2 framing Bearer 0 MSGc: -6 13 B: 227 238 M: 1 1 T: 0 63 R: 12 16 S: 0.1275 0.3945 L: 15055 5171 D: 1 1 I: 240 255 N: 240 255 Q: 4 0 V: 0 0 RxQueue: 99 0 TxQueue: 33 0 G.INP Framing: 18 0 G.INP lookback: 31 0 RRC bits: 0 24
Re: ECI Cabinets
13-02-2021 8:01 PM
Re: ECI Cabinets
14-02-2021 12:46 PM
Still on here
- « Previous
- Next »
