ECI Cabinets
ketleystar
Re: ECI Cabinets
Hi @bobpullen
I am on ECI cabinet. Can you put me on too. Would like to see G.INP enabled to get extra 10-12Mbps speed.
maranello
Re: ECI Cabinets
How can I find out if I'm on an ECI cabinet?
My other car isn't a Ferrari
goldenfibre
Seasoned Pro
Fixes: 12
Re: ECI Cabinets
@maranello you can check your cabinet here: https://kitz.co.uk/adsl/cabinet-lookup.htm
maranello
Re: ECI Cabinets
@goldenfibre
Thanks.
It's a Huawei.
kitz
Re: ECI Cabinets
@bobpullen
The article seemed to infer it was on an ISP basis, but if it is on a line basis then sign me up please.
I'm on an ECI DSLAM and it worked fine during the last (short lived) time it was active.
jonathant
Re: ECI Cabinets
Please can you volunteer me too if it's on a per-line basis. I'm on an ECI cabinet.
Do you need my Plusnet username (I'm not sure if the forum accounts are linked).
Thanks!
celsoazevedo
Re: ECI Cabinets
@bobpullen You can add my line too (ECI). Right now I'm on fastpath, but it usually goes back to inteleaved after 3-4 months which is quite annoying.
Bp1000
Re: ECI Cabinets
I’d like to volunteer too please
Also on an ECI cab
FrazUK
Re: ECI Cabinets
I volunteer for this too!
I actually mentioned this to the bloke when I phoned about renewing my contract a few days ago and asked him to put a note on my account that I'd like to opt in if Plusnet are doing the trials. He didn't know what G.Inp was but he put a note on my account anyway, dunno if it will be noticed.
I had G.Inp back when they first rolled (2016?) it out o ECI cabs and it made a night and day difference to my connection. From millions of FECS a day to pretty much 0 and never any drops as well as much more stable online gaming and pings the same as fast path.
digit101
Re: ECI Cabinets
Hi, I would like to be considered for this trial if possible?
I'm on a long line which is stuck on interleaving.
hex
Re: ECI Cabinets
Bit late to the party but only just noticed this,   I would like to register my interest also if there are plans to trial this - on an eci line and had a few sharp drops in speed and line quality when some new build customers were connected so would be interested to see if this helps.
Dodger21
Re: ECI Cabinets
I would also like to give it a try, I posted in another thread I had issues with high in interleaving and I know my router supports ReTx / G.INP.
ryant704
Re: ECI Cabinets
@bobpullen
Is it possible to to get in on this trial as well please?
FrazUK
Re: ECI Cabinets
@bobpullen
Has there been any new info on this/do you know if Plusnet will be doing this trial or any info about when the trial will start? It was pencilled in for the 12th so just wondered if you'd heard anything.
Cheers!
bobpullen
Fixes: 315
Re: ECI Cabinets
@FrazUK, I've relayed everybody's interest and hope for there to be some movement next week 🙂
