Dropping connection
Fixes: 727
Re: Dropping connection
No problem @sep9001 In fairness the close button is really close to the view button.
I've gone to book the appointment but based on availability there aren't any slots available I'm afraid.
I've added a list of the available slots for the next two weeks to your fault ticket 192846897. It's worth noting that we see a live appointment system so these slots may change by the time we go to book the engineer.
Feel free to nudge us over here once you've responded to the ticket.
sep9001
Morning @Gandalf ,
Thank you for looking into the ticket. I have responded to the ticket.
Fixes: 727
Hi @sep9001
That's all booked in for Friday morning, let us know how it goes.
sep9001
Hi
The engineer came checked everything at home which was fine, went to the box and did something and my connection was stable for a while, however as before for some reason my connection drops every so often.
Looking at my router stats it dropped again about 15 hours ago, at least this time the Down Stream and Up Stream have not dropped as last time:
VDSL Link Downstream Upstream
Link Rate 60154 Kbps 14175 Kbps
Line Attenuation D0( 13.8) D1( 37.8) D2( 60.4) dB U0( 6.1) U1( 30.7) U2( 48.8) U3(N/A) U4(N/A) dB
Noise Margin D0( 4.5) D1( 4.5) D2( 4.7) dB U0( 3.9) U1( 3.8) U2( 3.7) U3(N/A) U4(N/A) dB
VDSL2 Profile Profile 17a
Why does it keep dropping the connection, is it that there are too many connections in the green BT box and when someone tries to connect or fix someone else issues it causes issues on my line.
Log from from the router:
[Time synchronized with NTP server 0.uk.pool.ntp.org] Sunday, October 06,2019 00:26:42
[Internet connected] IP address: 209.93.141.179 Sunday, October 06,2019 00:26:39
[DSL: Up] Sunday, October 06,2019 00:26:06
[Internet disconnected] Sunday, October 06,2019 00:25:46
[DSL: Down] Sunday, October 06,2019 00:25:36
Please help, can someone please look into this for me.
Thank you
Fixes: 43
Hi @sep9001,
I'm sorry to hear the connection dropped out again. I've tested your line this morning and from what we can see everything appears to be working as expected, with only a couple of drops in the last 9 days. Occasionally, the connection may drop out, but this isn't something we'd consider a fault unless it happens repeatedly over a short period of time. It may be worth keeping an eye on the connection over the next few days to see if any further drops occur and if they do then it may be worth trying find any kind of pattern behind the drops. Let us know how this goes and we'll be happy to pick this back up for review.
 Alex H
