Dropped packets again
plusmore
There was some sort of reset on my router yesterday morning since when I am getting video judders and issues connecting to remote servers. Checking TBB it looks like dropped packets are back again for me, I am on Colindale pcn-bng01. I tried rebooting my router but have remained on the same PoP.
Any chance of a comment from PN staff - is Colindale playing up again?
11 REPLIES 11
Re: Dropped packets again
@plusmore - You might want to obscure your IP in the image, no point in attracting attention to yourself.
scrookes
Fixes: 4
I am running some checks for you now @plusmore
plusmore
@Anonymous Oops - good spot. Thanks
scrookes
Fixes: 4
Dropped a PM to you @plusmore
plusmore
Having worked with @scrookes to get some tests run and then forcing my link to switch over to pcn-bng02 it looks like the issue has cleared
scrookes
Fixes: 4
Thanks for the update @plusmore.  We're looking further as per our conversation and will keep you posted.  Glad to see the hop resolved it for you though.
rongtw
Fixes: 12
@scrookes  the problem is not fixed obviously pcn-bng01 is not performing correctly , so if he hops back on to pcn-bng01  the packet loss will reappear .
Or am i missing something ?
scrookes
Fixes: 4
No that is incorrect. With @plusmore's help we identified something that we've worked on and should have resolved. The problem right now is closed and fixed.
MrAlex
Hi Plusmore,  how did you insert the thinkbroadband graph, I have network latency issues and want to post my thinkbroadband graph but get errors when I try to Copy and Paste it?
Thanks,
Alex
plusmore
Just use the button I have indicated to attach a picture or screenshot
MrAlex
Thanks Plusmore.
Very interesting the post I'm trying to Reply to doesn't have that icon.  However this Reply does have the icon - weird.  My problem not yours, I now know what I'm looking for so will do some experimenting with different browsers and so on.
Many thanks for getting back to me so quickly, and your thinkbroadband graph idea has been super helpful Smiley
