Dropouts
- Dropouts
Re: Dropouts
23-01-2019 9:53 PM
Now 7 days uptime since faceplate removed😁. Quietly confident resolved, but it did do this once before. It's a pity that bt kit reboots every 14 days. Anyone any ideas why this is. Anyhow will continue monitoring, but if resolved will have to get a new plate as shmbo says the test socket with a filter looks untidy. Is the mk4 with an nte5c any good.....
Re: Dropouts
24-01-2019 10:32 AM
Glad that this is looking good, @penfold.
I'm sure that the learned members of our community will be able to assist with the BT/socket related queries.
If there's anything you need in terms of the connection, just drop us a line.
Best wishes
Dave
Re: Dropouts
06-05-2019 5:31 PM
Sorry to be revisiting this, but its started again with random sync drops. Nothing's changed my end, router still in the test socket. Will monitor but if it continues will raise a fault. Can anyone post up my radius stats, and run a gea test....
Re: Dropouts
06-05-2019 6:24 PM
Hi @penfold
Thanks for getting in touch - Can I just confirm that this is for your own personal account? I'll take a look at this for you tonight but don't want to pull the GEA for the wrong account
Dave
Re: Dropouts
06-05-2019 6:29 PM
Re: Dropouts
06-05-2019 7:08 PM
Re: Dropouts
06-05-2019 7:12 PM
I checked at the cab, earlier on when it was dropping, but no bt presence, cab is a 10second walk away around the corner.... Can you get my radius logs, to see if there is any pattern there. I've done a quiet line test and it's silent, and tried ringing out and in, but no drops. Drops continued after this, as my thinking was to clear a dirty joint by passing current down the line by ringing.
Re: Dropouts
06-05-2019 7:16 PM
RADIUS graph here.
Definitely a few drops there, so worth monitoring and raising a fault as you've suggested.
Let us know if/when you raise a fault and we'll ensure it gets picked up.
Cheers
Dave
Re: Dropouts
06-05-2019 7:29 PM
Re: Dropouts
06-05-2019 7:32 PM
All good ideas - let us know how you get on.
Dave
Re: Dropouts
08-05-2019 3:42 PM
Re: Dropouts
08-05-2019 4:19 PM
Hi @penfold
Good to hear that it's looking ok at the moment!
In regards to your DLM question - we can view more specific DLM history and change data.
We can see things such as dB changed over the last "X" days etc...but there's no way of seeing the reasons for a change as far as I'm aware.
Kind Regards,
MoR
Re: Dropouts
08-05-2019 4:37 PM
Any ideas what could cause a flurry of resyncs over a few hours and then just stop. Would you possibly be able to run another gea test, I would be interested in the errors detected on the line at almost 2 days uptime. Btb hub 6 won't give that detail.
Re: Dropouts
08-05-2019 4:53 PM
@penfold - please do keep monitoring and update us if anything changes.
If we can do more to help we certainly will.
Kind Regards,
MoR
Re: Dropouts
27-08-2019 9:17 PM - edited 27-08-2019 9:18 PM
Apologies for resurrecting this, but the thread contains a lot of details. The drops have started again, and are today much worse, the line has not been stable since 6ish tonight, despite reboots etc. This is the worst it has been. Rang in, line check ok, and was advised to change filter. I have changed filter but it still drops randomly. The upstream attainable rate has dropped from just below 30mbos to 23, and upstream to around 65, from high 70s. I have raised a fault via the troubleshooter. Can you post up the results of the gea test and the radius logs. I suspect I need an engineer, can someone pick this up for me. Interestingly DLM is not intervening at the moment
