Dropouts
- Dropouts
Dropouts
14-08-2018 11:33 AM
Since joining Plusnet Fibre, I have suffered numerous dropouts. Having raised a question witht support and after several weeks having a relatively stable system, yesterday I had three dropouts in 12 hours.
The support engineer had told the dropouts I am seeing are with the expected tolerance but not an actual quantitive measure. Can anyone tell me what this might be?. In my opinion, one when communicationg via broadband, is unacceptable.
Incidently, my issue was handled through the 'Questions' process but now this case has been closed, I don't appear to be able to raise a new question. Is this method no longer available?
Re: Dropouts
14-08-2018 2:58 PM - edited 14-08-2018 2:59 PM
Hi @Clarity3,
Thank you for getting in touch. I'm sorry for any inconvenience that this issue is causing you. There isn't a specific measure that we use for how many drops over a particular period of time would indicate a fault, but as a general rule of thumb we'd say that we would expect six drops or fewer over a 72 hour period and that anything more than this is likely to indicate a problem.
Your connection has had three drops over the last 72 hours:
and testing your line isn't picking up any issues and indicates that your line is currently syncing at 21.8mbps which is at the top end of the line's estimate of 13-22mbps.
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 21.8 Mbps | ||||
Upstream Speed | 2.3 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 1494.7 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Very Good | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-40M Downstream 3dB, Retransmission High - 0.128M-10M Upstream, Error Protection Off | ||||
Time Stamp | 2018-08-01T14:30:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 20.8 Mbps | 21.8 Mbps | 20.9 Mbps |
Up Stream Line Rate | 2.0 Mbps | 2.2 Mbps | 2.1 Mbps |
Up Time | 641.0 Sec | 900.0 Sec | 898.9 Sec |
Retrains | 0.0 | 7.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-08-14T13:05:35Z | 2018-08-14T13:20:35Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Please keep an eye on your connection, if you find that the drops become more frequent please report the issue here and let us know when you've completed it - we'd then be able to investigate this further for you.
Re: Dropouts
26-09-2018 2:45 PM
Hello Emily
Thank you for the information in your last email and the illustration below.
I am still concerned about the dropouts I am seeing. As with issues like this, they always occur when in the middle of a critical requirement. I am currently communicatiing with Australia to provide progress and receive data updates for an ongoing project. Recently, the dropouts I am getting have interrupted this process on two occassions, one of them today, where it took four attempts to get a stable connection (my judgement based on the number of time the flashing 'b' appeared in conjunction with the orange bar) with the activity bar returning to blue.
I appreciate your specification of 6 dropouts in 72 hours and although one dropout while at a vital stage is a nuisance, two is more than an embarrassment. I am trying to understand why, with my previous provider, I never saw a single dropout. Clearly, there could have been dropouts but none occurred while I was at my PC's. Please can you help explain why this change is occurring.
Regards
Re: Dropouts
26-09-2018 8:15 PM
Hi @Clarity3,
It's hard to say why the connection has become more unstable until we resolve the issue and so for the time being it's best for you to observe the connection and see if the drops coincide with anything else being turned on in the property.
If the issues continue to occur, I'd also recommend going through our online troubleshooting guides which can be found here and here.
