Dropbox no connection
RMFH
Since Switching to plus net fibre and the hub they supplied none of my PCs connect to dropbox.
OneDrive works fine but Dropbox keeps giving message can't establish a secure connection. I've tried re-installing dropbox but then that fails with an error that I'm not connected to the internet. Which i clearly am.
I can only assume that the plus net hub is blocking dropbox. But I can fine nothing in the settings that looks like wit would help.
Is there a setting I can switch or Do I have to go and buy a better hub?
Fixes: 256
Re: Dropbox no connection
I've used Dropbox with no issue on the hub one.
Do you have safeguard switched on?
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
RMFH
HI,
No, I've just double checked and no also the plus net firewall service is switched off.
Fixes: 454
Hi there.
This is a bit of an odd issue, can you try a factory reset of the router by pushing a paperclip into the reset hole at the back for 20 seconds?
Let us know how this goes.
RMFH
Thanks for coming back.
I think I may have fixed it by changing both the dropbox version and the anti-virus + a few network settings.
Fixes: 454
Glad to hear that! Thanks for letting us know, this will help others in a similar situation.
