Drop outs
FIXED- Subscribe to RSS Feed
- Drop outs
28-01-2019 7:35 PM - edited 28-01-2019 7:37 PM
Fixed! Go to the fix.
Re: Drop outs
29-01-2019 9:49 AM - edited 29-01-2019 9:50 AM
Hi @Pipachalk,
Thank you for getting in touch. I've tested your line, however the test isn't picking up any problems from here and indicates that your line is currently syncing at the full 40mbps down and 10mbps up:
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 40.0 Mbps | ||||
Upstream Speed | 10.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 501.4 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Very Good | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-40M Downstream, Error Protection Off - 0.128M-10M Upstream, Error Protection Off | ||||
Time Stamp | 2019-01-16T09:45:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 39.9 Mbps | 39.9 Mbps | 39.9 Mbps |
Up Stream Line Rate | 9.9 Mbps | 9.9 Mbps | 9.9 Mbps |
Up Time | 900.0 Sec | 900.0 Sec | 900.0 Sec |
Retrains | 0.0 | 0.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-01-29T09:17:11.669+00:00 | 2019-01-29T09:32:11.669+00:00 |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
and your connection log shows a solid connection with no drops for the last 76 days:
Are you experiencing connection problems with any of your other devices or is it just when streaming NowTV?
Re: Drop outs
29-01-2019 5:23 PM
Thanks for your reply. It’s mainly when watching now tv. Sometimes my phone won’t load a website and when I switch WiFi off it loads straight away in my mobile data signal.
Could it be the modem?
Re: Drop outs
30-01-2019 8:44 AM
Hi @Pipachalk,
Thank you for confirming that. From what you've said, it sounds like the problem lies with the wireless signal from the router.
The guide below will show you how to log into the router and change the wireless channel as it's usually another router in the area on the same or similar channel that will be causing issues for both wireless frequencies. Before picking a channel I'd suggest downloading a free app called wifi analyser which will scan your area for all the routers and show what channels they are on between 1-13. Although the above app isn't essential it helps you pick where your router would be best in terms of channels and saves a lot of time doing it via trial and error.
1) To connect to your Hub One, you will need to open a browser and go to 192.168.1.254 If you have any issues doing this via Wireless, we recommend trying to do it via Ethernet cable instead.
2) You should come to a page with information about your connection, click 'Advanced Settings' at the top and it will ask you to sign in with a Password. This is located on the back of your router under 'Admin Password'
3) Select the option for 'Wireless' followed by '5 GHz Wireless'. What we want to do to begin with is turn 'Sync with 2.4 GHz Wireless' to 'Off' and update the SSID to be different. The easiest way would be to add '-5G' to the end so it is identified as its own connection. Once this is changed, we will need to keep an eye on it for a day or 2 to see if the issue continues. If it does, the next step would be to change the wireless channel. Keeping in mind the original 2.4Ghz unchanged name network connection would be the best to connect your devices to for a stronger signal.
4) Following the above guide to get to your 'Advanced Settings' page, you will need to change the settings within the 2.4 GHz Wireless tab and the 5 GHz Wireless tab.
5) Under the correct heading, you will need to find 'Channel Selection' on the list and change this from 'Automatic' to any one of the other channels, This can also need doing under '5 GHz Wireless' to cover both signals. Give it 3-4 hours of testing to see if the issue still persists and try to change the channel again if you see little or no improvement.
Please let us know how it goes.
Regards,
Emily
Re: Drop outs
30-01-2019 7:53 PM
So I have followed steps 1 2 and 3 to change ssid name to add -5g to end of name. Is that it for now? Do I only follow the other steps if this doesn’t help as it says you will need to keep an eye on that for a couple of days and change the channel only if the issue persists. Is this correct?
I am unable to check the channels as the apps only work with android and not iOS it says on internet. I have an iPhone only.
31-01-2019 8:22 AM
Hi @Pipachalk,
Thank you for splitting the wireless bands. Please try changing the wireless channel if the issue persists over the next few days. Don't worry if you're not able to download the WiFi analyser app - just try a few different channels until you find one that's stable.
