Drop outs
Ruttla
Drop outs
I am experiencing intermittent drop outs. Its whilst generally surfing on a desktop or mobile device, both using WiFi. Sometimes the connection will go completely, followed by orange warning light on my router. Other times the light stays blue on the router, but my device is left buffering with no connection.
Lovelythanks
Re: Drop outs
I’ve been having similar problems since last night too.. im in Chester.. as usual I can’t find any confirmation of a problem or works being carried out here
Fixes: 8
Re: Drop outs
Hi @Ruttla
Thanks for getting in touch - sorry to hear you're experiencing drop outs.
If the orange warning light is being displayed by the router that usually indicates a physical break in the connection between yourself and the BT exchange. Conversely, if the light stays blue that's usually a wifi issue.
I'd initially recommend looking at our troubleshooting options here
If you follow that through and the orange light continues to display when the connection drops, I'd suggest that you raise a fault here
Let us know how you get on.
Thanks,
Dave
 Dave G
