Drop in sync speed since switching to Plusnet
- Drop in sync speed since switching to Plusnet
18-04-2016 10:12 AM
I moved over to plusnet from Sky on the 1st April. For the past 18months since I had FTTC activated at my cab I've been getting around 60meg. It would change sync speed every few weeks, but other than that was pretty stable.
Since I switched I've been 'stuck' on 47meg, I gave it benefit of the doubt for the first 2 weeks to see if it would settle down - but its remained the same. I kept the same modem (HG612) connected, and didn't reboot it or anything for fear of upsetting DLM.
I've since rebooted the modem last night, and I'm seeing hundreds of errors accruing which I think maybe keeping DLM from upping the speed?
How best to proceed, I wasn't going to raise a fault just yet as I don't think Plusnet can actually reset DLM or anything anyway. But I don't want to sit and do nothing in the hope that some day it will go back up again. Is it possible the move has changed which line card or whatever I'm connected to in the cab - and this is now what I'm stuck with?
Some stats:
Downstream | Upstream | |
Attainable rate (kbit/s) | 47040 | 17323 |
SNR margin (dB) | 6.3 | 6.2 |
Line attenuation (dB) | 18.7 | 0 |
Output power (dBmV) | 13.9 | 7.5 |
Downstream | Upstream | Downstream | Upstream | |
Line rate (kbit/s) | 47723 | 17323 | 0 | 0 |
CRC errors | 1108 | 0 | 0 | 0 |
FEC errors | 114 | 16 | 0 | 0 |
HEC errors | 1341 | 0 | 0 | 0 |
Re: Drop in sync speed since switching to Plusnet
18-04-2016 11:23 AM - edited 18-04-2016 11:38 AM
I'm just running a few tests on your line.
[edit]
Your issue isn't caused by DLM as your current profile is "0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off"
It'll be tricky to get our suppliers to investigate this as your estimated sync speed range is 61.7 to 46.5mbps so it's technically within estimates.
18-04-2016 12:24 PM
Thanks for looking, and I know there's a limited amount you can do. But it's really frustrating that I've lost ~20% of my speed by switching supplier. You would think, connected to the same cab with the same equipment at the prem that the sync speed should be within a much smaller margin.
