Drop in Fibre BB speed
johns
I have noticed a significant reduction in the broadband speed from 37 mb to 10 mb. I have checked the speed through Ookla and consistently getting only 10 mb.  I have noticed the speed reduction this evening. Any issue on PN side ?
thesawdust
Re: Drop in Fibre BB speed
Hello,
login to the router, under broadband hit disconnect wait 30 seconds and click connect. Then run tests again, and report back here  Smiley
johns
As suggested, I disconnected and connected back the router. However, there is no improvement in speed and the speedtest shows ~10 MB.
Are you testing via a wireless or ethernet cable connection to your router?
If it's wireless, and you are using a laptop or desktop PC of some kind, try connecting via cable and re-test.
