Drop in Fibre BB speed
- Drop in Fibre BB speed
11-02-2015 9:22 PM
I have noticed a significant reduction in the broadband speed from 37 mb to 10 mb. I have checked the speed through Ookla and consistently getting only 10 mb. I have noticed the speed reduction this evening. Any issue on PN side ?
Message 1 of 4
(612 Views)
3 REPLIES 3
Re: Drop in Fibre BB speed
11-02-2015 9:29 PM
Hello,
login to the router, under broadband hit disconnect wait 30 seconds and click connect. Then run tests again, and report back here
Message 2 of 4
(391 Views)
11-02-2015 10:39 PM
As suggested, I disconnected and connected back the router. However, there is no improvement in speed and the speedtest shows ~10 MB.
Message 3 of 4
(391 Views)
12-02-2015 12:00 AM
Are you testing via a wireless or ethernet cable connection to your router?
If it's wireless, and you are using a laptop or desktop PC of some kind, try connecting via cable and re-test.
Message 4 of 4
(391 Views)
