Drastic Slowdown :(
- Drastic Slowdown :(
Drastic Slowdown :(
28-12-2015 12:49 PM
These are the results I am getting from doing diagnostics:
Download speedachieved during the test was - 28.12 Mbps
For your connection, the acceptable range of speedsis 60 Mbps-29.88 Mbps .
Additional Information:
IP Profile for your line is - 29.88 Mbps
Upload speed achieved during the test was - 2.74Mbps
Your service was found to be performing poorly.
Please raise a fault with your service provider, stating that the BT Performance Tester tool indicates poor service throughput performance after the third test.
Why would my IP Profile be 29.88 Mbps? Shouldn't it be closer to 80?
Any help would be amazing! Thanks!
Re: Drastic Slowdown :(
28-12-2015 12:56 PM
Download speedachieved during the test was - 4.53 Mbps
For your connection, the acceptable range of speedsis 60 Mbps-9.86 Mbps .
IP Profile for your line is - 9.86 Mbps
Upload speed achieved during the test was - 5.37Mbps
28-12-2015 2:26 PM
Phil
28-12-2015 4:32 PM
So you paying £5 for nowt
28-12-2015 5:53 PM
Soooo I am getting nothing by having the Pro Addon?
28-12-2015 5:54 PM
Quote from: PeeGee Did you "rearrange" the wiring? It would help to know what exactly you did with the internet connection/wiring - changed cables etc. Were your tests wireless? If so, can you test using a cabled connection to eliminate wireless oddities (though the downstream test suggests a different problem)?
Phil
It was direct ethernet connection from computer to Openreach box while doing those tests, so no there was no wireless.
I would expect its something with the IP Profile maybe for downstream? as the Upstream is correct at 20mbps but only doing about 5/6 up, kinda funny doing more up then down.
29-12-2015 9:46 AM
It seems that something between your modem and the cabinet has changed.That covers internal/external wiring and plugs/sockets/filters. Has there been any BT work during the time? Did you loosen the box (and possibly loosen a connection)?
One thing I forgot: have you checked the phone (17070 option 2 for a quiet line test) for problems?
Phil
* Simplified explanation
29-12-2015 4:27 PM
mav:quote
29-12-2015 6:16 PM
Here is the latest tests from BT speedtest,
Download speedachieved during the test was - 42.65 Mbps
For your connection, the acceptable range of speedsis 60 Mbps-47.8 Mbps .
IP Profile for your line is - 47.8 Mbps
Upload speed achieved during the test was - 7.14Mbps
29-12-2015 8:48 PM
Exactly the last 2 days, i have went from 60mb down to 5mb down.
My usual testing + latency, VIA ethernet & TP Link on other computers, have always been.
55+down / 15+ up - From all ends, with a latency of average 20-30ms.
As of 2 days ago, ive now got this.
http://www.speedtest.net/my-result/4954121681
So, clearly something is wrong, and i can assure you, absolutely no changes have been made to my routers,modems, wiring, settings, nothing.
Ive tried flushing, ive tried turning the router off, 5minutes > on, and THAT made the situation worse, as now im getting the above results, which i used to get 25mb, which even then is still nowhere near my usual speeds.
Estimated line speed:
Current line speed:
59.8 Mb
[Imgur](http://i.imgur.com/ZOZuD4u.jpg)
29-12-2015 11:22 PM
