Downstream decreased
alephant
Would you mind looking at my line and seeing if anything indicates a fault? I noticed that my line speed has started to decrease quite significantly.
Hub one
Downstream: 52.51 Mbps
Upstream: 20 Mbps
Speedtest
Retrieving speedtest.net server list...
Selecting best server based on ping...
Hosted by Structured Communications (London) [2.56 km]: 26.13 ms
Testing download speed................................................................................
Download: 47.52 Mbit/s
Testing upload speed....................................................................................................
Upload: 18.05 Mbit/s
A couple of months ago my line had some problems (ref to https://community.plus.net/t5/Fibre-Broadband/Speed-Capped/m-p/1474818) that were quickly fixed, but now I have lost about 15mbps in downlink again, and this time this is already visible from the downstream in the hub (download speed is just a consequence).
Thanks and regards
1 REPLY
alephant
Re: Downstream decreased
Dear Plusnet support,
I just observed that my Hub One had a disconnection and reconnection 4 minutes ago.
I wonder if this happens frequently, I will try to monitor. But could this be the reason why my downstream is lower than it should be?
After the last disconnection it is now 57 Mbps
