Downstream current rate getting worse, but max rate is increasing daily
thewanted
Hello,
I recently purchased a TP-Link TD-W9970 modem/router and it has been connected to PlusNet Fibre Extra for 11 days without any errors. I have noticed however that my downstream current rate keeps getting worse daily, whilst my max rate keeps increasing.
Why is this happening, and can it be resolved?
Fixes: 181
Re: Downstream current rate getting worse, but max rate is increasing daily
Sorry to hear your speeds are dropping.
I've tested your line and I can see your router is synced to the cabinet at 44.4mbps which is above your estimates.
As such we can't investigate further as our suppliers wouldn't class this as a fault.
 Matthew Wheeler
thewanted
Thanks for replying Matthew.
I don't know why my estimate is so low because my sync rate with BT was ~58mbit before I moved to PlusNet recently.
Fixes: 359
It's possible that the dynamic line management software in the exchange put your connection on the 3db profile, which boosted your sync rate up. Upon migration to another provider, I believe a DLM reset is performed automatically.
If that is the case, 3db might return given time but it's sadly something we can't manually influence.
