Downloads speeds much lower than previously, any reason why?
- Downloads speeds much lower than previously, any r...
30-07-2015 10:29 PM
HI
Since I got fibre just over 2 years ago, my download speed has always hovered around the 7MB/s area but the last week or so I've noticed that it seems to have dropped down to about 5MB/s.
I looked on the BT speedtester site and it reported my sync as 46.97 Mbps or a max achievable speed of 49.99Mbps, this puzzles me as my connection has previously always been around 65Mbps or there abouts.
Any thoughts on why this has happenened?
Message 1 of 4
(672 Views)
3 REPLIES 3
Re: Downloads speeds much lower than previously, any reason why?
01-08-2015 11:42 PM
Have you tried power-cycling the Openreach modem?
Message 2 of 4
(404 Views)
02-08-2015 12:02 AM
I use to have 65MB myself so i know it sucks when you loose a chunk of it, sadly you have to be below your estimated range before Plusnet / BTW deem your loss worthy of investigation, I have a feeling they will say your still within that range if it's anything close to what mine is.
you could try a Modem reboot but only do it once, but even then I very much doubt it will help.
Message 3 of 4
(404 Views)
03-08-2015 11:59 AM
Message 4 of 4
(404 Views)
