Download throttle on Netflix
Weetos1977
Do Plusnet throttle or traffic manage the data I recieve from Netflix? I can't stream any better than 480 in stereo when I should be getting 1080 in 5.1(according to Netflix)
Spèed tested at 38 Mbps with no load and 30 when streaming Netflix.
8 REPLIES 8
Mav
Fixes: 515
Re: Download throttle on Netflix
Moderator's note by Mike (Mav): This thread is now in the appropriate board.
Forum Moderator and Customer
Fixes: 418
It won't be Plusnet throttling things. How are you connecting to the router? If it's wireless or powerline devices then that could be the problem. If you're not doing it already you need to to use an Ethernet cable to make sure that this is not the problem.
Terranova667
Fixes: 5
doesn't sound like a connection issue if it's getting 30Mbps whilst streaming that's more than enough for HD it only needs 5Mbps, I can stream 4K and i get around 35-38Mbps whilst streaming it only needs 25Mbps.
The OP does have the standard Plan with the video quality settings set to high or auto ? Basic plan is SD only, they are are not trying to watch HD content on the basic plan are they if so that would be the reason for only the SD (480) option.
Weetos1977
I do have the HD package for Netflix. ..there is no option on either my PS4 or my smart TV for high or auto.
Will put a wired connection and not using the power network adapters tonight, I get the same result when using WiFi too so don't think their causing the issue.
Fixes: 1,483
I can definitely stream 1080 with Netflix, PN don't throttle.
DaveyH
Champion
Fixes: 12
Its an option within your account, rather than a setting within the apps
https://help.netflix.com/en/node/11559
Fixes: 418
I have had exactly the same experience with both WiFi and Powerline units causing buffering. I installed a CAT5e cable with wall sockets to make a professional job of it. Since then I have had no buffering whatsoever.
Weetos1977
Ahhhhhh didn't know that and Netflix didn't even mention it when I've discussed the issue with them...it was on low so hopefully that will sort it...at work at the moment so unable to check, will report back later.
Thanks!!!
