Download speed
- Download speed
- « Previous
- Next »
Re: Download speed
25-10-2019 12:01 PM
Let us know how it goes please @jeldan,
Re: Download speed
25-10-2019 3:32 PM
You can cancel the engineer visit. I did a pin hole reset on the router and I have internet back (something that wasn't suggested when I phoned up to report the problem) so it was obviously a router problem and I've been without the internet for 4 days now.
Disappointed customer
Re: Download speed
25-10-2019 4:09 PM
Re: Download speed
25-10-2019 11:10 PM
Re the speed. At this moment I am getting 18Mbps. To answer your questions I am doing the test via a wired PC. I have also carried out the other checks as suggested and everything is how it should be.
I cannot understand why the speeds fluctuate so wildly, but whatever the reason I hope someone can sort it out.
Re: Download speed
25-10-2019 11:13 PM
Re: Download speed
25-10-2019 11:43 PM
Re: Download speed
26-10-2019 6:28 AM
Thanx, atleast I now know what to do if it happens again.
Re: Download speed
26-10-2019 3:50 PM
Hi @Robbo3, thanks for getting back to us.
I'm sorry to hear you look to have been incorrectly advised regarding the cashback process. Just to confirm the cashback process, within 10 days of the service going live customers receive a cashback redemption form. Once filled out the cashback will be sent however can take up to 30 days to arrive. I'm afraid the time frame you've been given around the cashback arriving is incorrect and the cashback reward should be with you by the 23rd of November at the very latest. By all means if you haven't received anything by the 23rd then please do let us know and we'll happily get this chased up for you.Again apologies for any inconvenience the incorrect information may have caused prior to this.
Having a check over your connection we are still seeing 31Mbps download getting to your router with no errors or faults been detested when testing both connection and line. If you're seeing speed fluctuate to as little as 7.1Mbps especially during the evenings on a wired connection your side (with no other devices/applications heavily using the connection) then it certainly hints something is out of place somewhere.
As we aren't detecting from this side what's causing the fluctuating speeds we'd recommend running through a few checks your side that may resolve the issue.
I'd recommend starting with basic checks here
And if that doesn't help the next thing would be to rule your internal wiring out by plugging the connection into your test socket which is under the faceplate of your master socket and seeing if the drops stop. This rules out internal wiring, face plates and extension sockets as being the cause. How to locate the test socket and set your connection into it can be found here: https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242https://community.p...
If the problem still persists from here we will go down the route of raising a fault . Let us know how it goes.
Re: Download speed
02-11-2019 5:59 PM
"measured my line speed at 32.2 Mbps" sounds like the quote I received from PN when my speed should be 38 to 40 and is actually 25 Mbps.
32.x is the exact speed for my FTTC connection where the ISP has to allow you to terminate without penalty, maybe yours too?
In most cases moving has no effect as all the wiring etc. is the same all the way to the Exchange, just the supplier (ISP) is different.
- « Previous
- Next »
