Download speed
- Download speed
Download speed
10-06-2016 8:11 AM
I recently switched from the 38mbps to the up to 76mbps package to take advantage of the fact my line can handle around 55mbps. After having my upload capped at 2mbps (and contacting tech support) it is now indeed around 55/10. This reflects in multi threaded speedtests, however single threaded downloads are lucky to get over 10mbps. It doesn't matter where I download from, it is all at the same low speed.
Is there a problem on the network? Before my upgrade I would consistently max out the 38 on single threaded downloads any time of the day.
Thanks.
Re: Download speed
10-06-2016 9:13 PM
Re: Download speed
10-06-2016 10:29 PM
That looks like the gateway you are logged into is having performance issues. The gateway is assigned when the router connects to Plusnet.
Gateway checker is http://users.plus.net/@gateway_custom?debug-ip=yes
The gateway name is shown in the text and its actual IP address is shown in the array output. There are multiple IP addresses per named gateway.
Changing gateway's may help, it does for me. You change by logging onto the router, click "Disconnect", wait a minute, click "connect" and then see if Plusnet have assigned a new gateway once the connection is up and running again.
Re: Download speed
10-06-2016 10:42 PM
Thanks for the reply, i will give this a try and see if it improves any.
Re: Download speed
11-06-2016 1:03 AM
Gave that a try, left my router off for a few minutes. But I still connected to the same gateway, psb-ir01 - I'm guessing I'm on the new network as I've never seen that one before.
Does it take longer to potentially choose another or does that now not apply?
Many thanks.
Re: Download speed
11-06-2016 9:05 AM
You are on the new network, so not so easy to gateway hop, if even possible.
But out what is the problem? You seem to be getting the 55/10 you were expecting?
Re: Download speed
11-06-2016 9:07 AM
Thanks for the reply.
Yes I am on multi threaded downloads, single is 10.
However within the last 20 minutes, single has now increased to 55, so I presume it was congestion or a change has been made.
Re: Download speed
11-06-2016 9:13 AM
Ah ok, glad it's sorted.
Re: Download speed
11-06-2016 9:43 AM
If it's lower regularly then it's worth reporting as a fault to us. It may be SVLAN congestion or similar so would be good to investigate.
Re: Download speed
11-06-2016 9:55 AM
It was low entirely throughout the day yesterday.
Re: Download speed
11-06-2016 10:30 AM
I am however getting the odd amount of packet loss here and there. I presume this is because my line is training and 55 potentially may be too much for it?
Re: Download speed
11-06-2016 3:58 PM
The 10mbps on single threaded downloads has returned. As per Chris Parr advice, please advise how I can log a fault for this to be investigated.
Re: Download speed
11-06-2016 3:59 PM
You can report a fault at https://faults.plus.net
