Download speed suddenly dropping
- Download speed suddenly dropping
08-11-2019 7:20 AM
Our download speed keeps dropping suddenly and significantly, upload speed according to the speed checker less affected.
The little network connection location (world symbol on speed check app) seems to change very frequently and depending upon where that seems to be picking up, depends on the speed.
Any ideas? It’s a bit like when you are sitting on the edge of 3 different phone mast areas with mobile signal and it depends what mood the phone is in as to which it connects to, our router seems to be doing the same?
Message 1 of 2
(376 Views)
1 REPLY 1
Re: Download speed suddenly dropping
08-11-2019 11:33 AM
Thanks for getting in touch @MrsB I'm sorry to see you're experiencing connection problems. I've tested your line today and the tests aren't showing any issues with the broadband signal going into your router. Based on this and what you've said, I suspect this is an issue with the wireless signal around your home.
Can you try changing what's known as the wireless channel, there's instructions Here and it may also be worth splitting the '2.4GHz' and '5GHz' frequencies apart, there's more steps Here.
Let us know how it goes.
Message 2 of 2
(350 Views)
