Download speed still slow after 3 months
Racalman
I switched to FTTC in August and was given an estimated download speed of 35-40Mbps (I am 900m from the cabinet).
The download speed has hovered consistently around 22Mbps and the SNR margin is 9dB (see attached stats).
I have tried to contact plusnet via online Chat but it isn't available. Can anyone here offer any hope that things will improve? It clearly won't happen by itself, so can I request a lower SNR margin?
Mike
Aspiring Hero
Fixes: 70
Re: Download speed still slow after 3 months
Plusnet has no control over SNR with fibre. The DLM sets it out automatically in its own mysterious and sometimes random ways.
If I am correct in assuming that FECS is Forward Error Correction Seconds then this is very high suggesting that there is a fault or interference getting in somewhere.
I would first do a quiet line test with a wired telephone by dialling 17070 and selecting option 2. If that is OK then plug your router via a filter into the Test Socket, that's the one that's exposed if you take the front section of of the BT Master Socket and do the BT wholesale speed test (http://www.speedtest.btwholesale.com/) including the further diagnostics. The results from the further diagnostics are logged so that Plusnet can see them.
If the phone quiet line test shows a noisy line you need to report a PHONE (not broadband) fault. Until that is fixed you will always get broadband problems.
As you say, after 3 months it's unlikely to fix itself. Let us know how you get on.
Fixes: 541
I'm sorry to hear you're experiencing speed problems and apologies for the delayed response.
It looks like something's happened in the past 3 weeks as testing your line now is showing a sync rate of 31.5mbps. It's still below your estimates of 34mbps so I'd run through the checks here.
If your speed doesn't change and you've tried a different modem, I'd head on over to http://faults.plus.net to report a fault.
