Download speed not quite right?
Furrball
When the service was initially provisioned there was a fault on the line that was capping the download to around 34Mb.
Since then the fault has been fixed and when the engineer was onsite he commented that on his test he was getting a full 80/20 connection.
Now the upload is fine, but given the line length and what Plusnet are reporting the download speed seems a little low.
GEA
Test Outcome Pass Test Outcome Code GTC_FTTC_SERVICE_0000 Description GEA service test completed and no fault found . Main Fault Location OK Sync Status In Sync Downstream Speed 68.4 Mbps Upstream Speed 20.0 Mbps Appointment Required N Fault Report Advised N NTE Power Status PowerOn Voice Line Test Result Pass Bridge Tap Not Detected Radio Frequency Ingress Not Detected Repetitive Electrical Impulse Noise Not Detected Cross Talk Not Detected Estimated Line Length In Metres 281.8 Upstream Rate Assessment Very Good Downstream Rate Assessment Reasonable
From Plusnet page
Estimated line speed:80Mb (This may vary between 66Mb and 80Mb) - Checked on 2017-10-19 14:52:50Current line speed:78 Mb
From BTWholesale
 Download speed
achieved during the test was - 64.09 Mbps
 For your connection, the acceptable range of speeds
is 40 Mbps-66.23 Mbps .
 Additional Information:
 IP Profile for your line is - 66.23 Mbps
9 REPLIES 9
adamwalker
Fixes: 221
Re: Download speed not quite right?
Hey Furrball,
I'm just taking a look at this now and will get back to you shortly.
 Adam Walker
adamwalker
Fixes: 221
As the fault we recently resolved was due to disconnections this means speeds were lowered deliberately by our supplier's DLM systems (dynamic line management) this does work in reverse when a connection has re-stabilised but can take a couple of weeks. Personally I would give it another week to give this a chance and failing that we would then need to arrange an engineer visit so they can initiate an SNR reset at the cabinet.
 Adam Walker
Furrball
Thanks for the prompt reply.
Shall see what it is like in a few weeks!
adamwalker
Fixes: 221
No worries Furbal! Smiley
 Adam Walker
Furrball
No change on the download speed so maybe time for an engineer kick?
Furrball
How do I escalate this to get an engineer visit?
Fixes: 1,600
Hi Furrball.
I'd report the fault to us at http://faults.plus.net but from testing your line I'm seeing your router in sync at 69mbps and there's no banding applied.
Sync Status In Sync
Downstream Speed 69.0 Mbps
Upstream Speed
20.0 Mbps
Profile Name 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
As your sync speed falls within your speed estimates it's likely that our suppliers wouldn't accept this as a fault.
Furrball
So looks like the line has sorted itself out and now connecting at full speed.  However profile seems to be 'stuck' as actual speeds still seem to remain the same
2018-01-26 15_46_37-BTW Performance Test.png2018-01-26 15_46_10-Member Centre _ Member Centre - Plusnet.png
Fixes: 1,600
Cheers for coming back to us.
I've bumped up the speed profile on your account now. If you can do a single disconnect/reconnect of the PPP session you should see an increase in your throughput.
