Download speed dropped
richandsian
I seem to have come home to < 1Mbps. I'm on a dodgy line anyway (BT say they're going to replace some of it, but I've no record of this or ETA), but usually at least 11Mbps is achievable.
Could someone see if there's anything they can do to improve it? I did try the fault checker but it told me to come back later...
Fixes: 22
Re: Download speed dropped
Hi Richard,
Can you please post all of the information asked for in the speed issues thread at the top of this forum.
Kevin
richandsian
BT speed tester:
Download speed (Mbps): 0.96
Upload speed (Mbps): 1.88
Ping Latency (ms): 61.75
Further diagnostics isn't working for me at the moment, I screwed up the first time and can't get it back. The IP profile down was about 12Mb though.
PN stats:
Estimated line speed:
Current line speed:
12.4 Mb
Fixes: 22
...and modem stats please...
I have presumed you are ADSL - yes?
Kevin
richandsian
No. FTTC.
Wrong forum  Smiley
A mod will probably be along to move it for you
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Fixes: 58
Moved.
Customer and Forum Moderator.
richandsian
Ok.
Any ideas about the issue...?
Plusnet Staff
Plusnet Staff
Fixes: 160
If you're still having the same problem can you finish answering the questions at https://faults.plus.net and we'll get this picked up and looked into.
 Chris Parr
 Plusnet Staff
